Fozzy
Hi folks,
I have a bit of a strange one - my temperature gauge is acting strange lately. I have always had an intermittent issue where sometimes the needle doesn?t move at all. If I tap the dash, it moves and has always stayed in the normal range after that. About 4-5 weeks back, I pulled into a petrol station after driving for 30 mins and noticed the needle really quickly went up to about three quarters, I turned off the engine and turned the ignition back on, it went immediately to the normal position. I assumed it was just the dodgy connection issue.
This morning, exact same thing happened but this time the fans stayed on for about 5 mins even when the needle was in its normal position. I?m not losing any coolant at all.
I understand that my car has two temp sensors - 1 for the ECU and 1 for the cluster. Until this morning I assumed that my cluster sensor was dodgy (or the wiring to it) but the fans coming on is leading me to believe that it might be another problem. Does anyone know how the fans are controlled - I assume it?s by the ECU?
I?ll plug it into a diagnostic and have a look at the temperature readings but in the meantime has anyone had or heard of similar issues or maybe have any suggestions or wisdom on this?
Cheers
Cheers
