Rear subframe Mounting point
enda
Did the STi change back to bushings in teh subframe from 2004 onwards ?
Just I noticed on mine(2003), its solid, and no washer required on the bolts to subframe mount...
But on the Web, ive seen ON 2004+ that they now use a washer, suggesting gone back to rubber bushes, or was it required to use a washer?
Just surious as when I was reassembling mine, I actually though it should have had a washer until I went back through photos and realized it never had them...
2 photos attached (s203 - no washer / s204 - washer fitted)
Not really sure Enda would have to check really I would have guessed they were the same but from the photos then no
Whatever was on yours leave it that way , the washers are used because the shoulder on the bolt is not wide enough to get a good grip on the bush as there is adjustment in the subframe , but some sub frames are solid mounted and I dont think these have the washers , I could be wrong though.
you could try Ali Burrows for that question
