off wrx
standard manifold
uppipe
altenator
aircon pump
inlet manifold ideal for some colour coding
yellow injectors with rail
timing belt covers and pulleys
idle control valve
sump
dipstick
cam/crank sensors
temp sensor
oil pressure switch
knock sensor
ignition leads
various other bits brackets and bolts
standard manifold
uppipe
altenator
aircon pump
idle control valve
sump
dipstick
cam/crank sensors
temp sensor
oil pressure switch
knock sensor
ignition leads
