Loss of Boost
bang
Ive been having an issue since Saturday when I lost boost while accelerating.
I use the ECUtek app and always have the advance multiplier gauge showing on screen.
I had this issue when I originally got mapped and the issue was I needed octane booster so have been putting in NF Race ever since with no issues until Saturday.
I'm kind of scrathing my head with this one as when I originally had the issue I replaced fuel pump and a new knock sensor also but it was the NF that fixed it.
I dont have the issue in low boost mode [0.7 bar], only have the issue so far in race mode [1.5 bar]
When the issue happened on Saturday I felt a fluttering vibration in the accelerator pedal and an audible clicking sound and that is when i looked at the screen to see the advance multiplier was reading 0 down from 1.00 and all boost lost
When I arrived at my destination I reset the ECU
On my way home I tested it again and the same happend, a vibration in the pedal and clicking sound and loss of all boost.
Ive been testing every day now and the same is happening.
I have attached my log file for anyone out there able to read and make sense of this.
Once the Advance multiplier drops below 1 thats when the issue starts.
Any ideas at all on what this could be?
Time (s)Log MarkAdvance MultiplierAir Flow Sensor Voltage (V)Air/Fuel Correction #1 (%)Air/Fuel Learning #1 (%)Air/Fuel Sensor #1 (AFR)Boost Error (bar)Coolant Temperature (°C)Engine Load (g/rev)Engine Speed (rpm)Fuel Injection #1 Pulse Width (ms)Ign. Cor. AK (Knock Ret.) (°)Ign. Cor. AP (Learnt Cor.) (°)Ignition Timing (°)Intake Air Temperature (°C)Intake VVT Advance Angle Left (°)Internal Boost Reading (bar)Knock Correction (°)Mass Air Flow (g/s)Throttle Opening Angle (%)Wastegate Duty Final - Primary (%)
167.82​
0​
1​
3.46​
0​
0​
13.65​
0.63​
90​
1.99​
3001​
12.8​
0​
0​
10.5​
37​
25​
1.82​
3.5​
108.07​
100​
98​
167.925​
0​
1​
3.54​
0​
0​
13.65​
0.58​
90​
2.09​
3124​
13.57​
0​
0​
11​
37​
28​
1.91​
3.5​
117.17​
100​
98​
168.105​
0​
1​
3.64​
0​
0​
13.19​
0.46​
90​
2.2​
3222​
14.59​
0​
0​
11​
36​
33​
1.99​
4​
126.9​
100​
98​
168.14​
0​
1​
3.7​
0​
0​
13.08​
0.42​
90​
2.31​
3349​
15.1​
0​
0​
11.5​
36​
37​
2.04​
4.5​
134.11​
100​
98​
168.197​
0​
1​
3.76​
0​
0​
12.85​
0.36​
90​
2.35​
3461​
15.36​
0​
0​
11.5​
36​
41​
2.06​
4.5​
143.29​
100​
98​
168.312​
0​
1​
3.8​
0​
0​
12.85​
0.34​
90​
2.42​
3561​
15.62​
0​
0​
11.5​
36​
42​
2.08​
4.5​
150.22​
100​
98​
168.405​
0​
1​
3.88​
0​
0​
12.62​
0.32​
90​
2.45​
3713​
15.87​
0​
0​
11.5​
36​
42​
2.08​
4.5​
156.13​
100​
98​
168.505​
0​
1​
3.9​
0​
0​
12.5​
0.32​
90​
2.48​
3825​
15.87​
0​
0​
11.5​
36​
42​
2.09​
4.5​
162.74​
100​
98​
168.601​
0​
1​
3.94​
0​
0​
12.39​
0.31​
90​
2.49​
3963​
15.87​
0​
0​
11.5​
35​
41​
2.09​
4.5​
165.3​
99.6​
98​
168.699​
0​
1​
3.96​
0​
0​
12.27​
0.31​
90​
2.48​
4074​
15.87​
0​
0​
11.5​
35​
39​
2.09​
4.5​
170.57​
100​
98​
168.797​
0​
1​
4​
0​
0​
12.27​
0.32​
90​
2.48​
4194​
15.87​
0​
0​
11.5​
35​
29​
2.08​
4.5​
174.74​
99.6​
98​
168.893​
0​
0.75​
4.04​
0​
0​
12.05​
0.32​
90​
2.48​
4345​
15.62​
0​
0​
9.5​
35​
21​
2.06​
2.5​
179.28​
71.8​
97.3​
169.101​
0​
0.25​
4.02​
0​
0​
12.05​
0.21​
90​
2.42​
4359​
12.54​
0​
0​
17.5​
34​
20​
1.02​
0.5​
23.14​
7.8​
0​
169.102​
0​
0.25​
1.78​
0​
-0.8​
11.59​
-0.17​
90​
0.64​
4260​
2.3​
0​
0​
17​
34​
19​
0.27​
0​
9.55​
3.5​
0​
169.176​
0​
0.25​
1.5​
0​
0​
11.47​
0.1​
90​
0.21​
4147​
0.77​
0​
0​
17​
34​
18​
0.14​
0​
3.12​
1.6​
0​
169.288​
0​
0.25​
1.02​
0​
0​
12.16​
0.27​
90​
0.06​
3958​
0.77​
0​
0​
17​
34​
17​
0.11​
0​
2.25​
2.4​
0​
169.381​
0​
0.25​
1.26​
0​
-0.8​
12.85​
0.3​
90​
0.05​
3797​
0.77​
0​
0​
17​
34​
15​
0.11​
0​
4.57​
2.7​
0​
169.494​
0​
0.25​
1.34​
0​
-0.8​
13.77​
0.33​
90​
0.07​
3454​
1.28​
0​
0​
23.5​
33​
10​
0.19​
0​
66.09​
60​
69.8​
169.575​
0​
0.25​
3.02​
0​
0​
14​
1.58​
90​
0.83​
2992​
7.42​
0​
0​
16​
33​
3​
1.08​
0​
65.66​
100​
90.6​
169.684​
0​
0.25​
3​
0​
0​
14.45​
1.3​
90​
1.15​
3240​
7.94​
0​
0​
16​
33​
13​
1.17​
0.5​
72.91​
100​
98​
169.777​
0​
0.25​
3.08​
0​
0​
13.88​
1.23​
90​
1.35​
3157​
8.7​
0​
0​
12.5​
33​
18​
1.27​
0.5​
78.44​
100​
98​
169.96​
0​
0.25​
3.2​
0​
0​
13.42​
1.11​
90​
1.47​
3161​
9.47​
0​
0​
7.5​
33​
22​
1.41​
0.5​
85.89​
100​
98​
169.961​
0​
0.25​
3.3​
0​
0​
13.77​
1.01​
90​
1.59​
3325​
10.5​
0​
0​
7.5​
33​
26​
1.51​
0.5​
97.77​
100​
98​
170.081​
0​
0.25​
3.4​
0​
0​
13.65​
0.84​
90​
1.78​
3227​
11.78​
0​
0​
8​
33​
29​
1.68​
1​
106.31​
100​
98​
170.18​
0​
0.25​
3.54​
0​
0​
13.31​
0.73​
90​
1.92​
3332​
13.06​
0​
0​
8​
33​
33​
1.83​
1​
121.36​
100​
98​
170.26​
0​
0.25​
3.66​
0​
0​
12.96​
0.55​
90​
2.12​
3391​
14.34​
0​
0​
8​
32​
36​
1.95​
1​
129.55​
100​
98​
170.37​
0​
0.25​
3.74​
0​
0​
12.39​
0.4​
90​
2.26​
3414​
15.36​
0​
0​
8​
32​
37​
2.04​
1​
137.24​
100​
98​
170.464​
0​
0.25​
3.74​
0​
0​
12.27​
0.34​
90​
2.36​
3455​
15.87​
0​
0​
8​
32​
37​
2.1​
1​
142.98​
100​
98​
170.562​
0​
0.25​
3.82​
0​
0​
12.05​
0.29​
90​
2.43​
3545​
16.13​
0​
0​
7​
32​
37​
2.12​
0​
147.24​
100​
98​
170.652​
0​
0.25​
3.82​
0​
0​
11.93​
0.29​
90​
2.48​
3592​
16.13​
-1.4​
0​
7​
32​
36​
2.15​
0​
152.66​
100​
98​
170.747​
0​
0.25​
3.88​
0​
0​
12.05​
0.26​
90​
2.51​
3630​
16.38​
-2.8​
0​
5.5​
32​
36​
2.17​
-1.5​
159.27​
100​
98​
170.852​
0​
0.25​
3.9​
0​
0​
12.16​
0.23​
90​
2.55​
3745​
16.38​
-4.2​
0​
2.5​
32​
35​
2.17​
-4.5​
162.05​
100​
98​
171.028​
0​
0.25​
3.94​
0​
0​
12.16​
0.22​
90​
2.61​
3749​
16.9​
-5.6​
0​
2.5​
31​
34​
2.19​
-4.5​
166.41​
100​
98​
171.087​
0​
0.25​
3.98​
0​
0​
12.16​
0.21​
90​
2.63​
3780​
17.15​
-5.6​
0​
2.5​
31​
33​
2.21​
-4.5​
172.09​
100​
98​
171.138​
0​
0.25​
4​
0​
0​
12.27​
0.2​
90​
2.65​
3898​
16.9​
-7​
0​
1.5​
31​
32​
2.2​
-6​
173.22​
100​
98​
171.238​
0​
0.25​
4.02​
0​
0​
12.05​
0.2​
90​
2.68​
3943​
17.15​
-3.85​
0​
5​
31​
31​
2.21​
-1.5​
177.01​
100​
98​
171.336​
0​
0.25​
4.04​
0​
0​
12.05​
0.2​
90​
2.67​
4005​
16.9​
0​
0​
8.5​
31​
29​
2.21​
1​
177.77​
100​
98​
171.439​
0​
0.25​
4.04​
0​
0​
12.05​
0.19​
90​
2.66​
4068​
16.64​
0​
0​
7​
30​
26​
2.19​
0​
178.9​
100​
98​
171.532​
0​
0​
4.04​
0​
0​
12.05​
0.21​
90​
2.63​
4087​
16.64​
0​
0​
7​
30​
24​
2.2​
-1.5​
180.04​
100​
98​
171.639​
0​
0​
4.04​
0​
0​
12.05​
0.21​
90​
2.61​
4151​
16.64​
0​
-1.4​
5.5​
30​
23​
2.18​
-1.5​
184.37​
100​
98​
171.732​
0​
0​
4.08​
0​
0​
12.16​
0.22​
90​
2.63​
4218​
16.64​
0​
-1.4​
5.5​
30​
22​
2.18​
-1.5​
188.07​
100​
98​
171.922​
0​
0​
4.1​
0​
0​
12.16​
0.21​
90​
2.64​
4255​
16.64​
0​
-1.4​
5.5​
30​
22​
2.2​
-1.5​
188.89​
100​
98​
171.923​
0​
0​
4.1​
0​
0​
12.05​
0.21​
90​
2.62​
4300​
16.38​
0​
-2.8​
4.5​
29​
21​
2.19​
-3​
189.71​
100​
98​
172.034​
0​
0​
4.12​
0​
0​
12.05​
0.21​
90​
2.63​
4400​
16.38​
0​
-2.8​
4.5​
29​
20​
2.19​
-3​
193.83​
100​
98​
172.133​
0​
0​
4.12​
0​
0​
12.16​
0.22​
90​
2.62​
4376​
16.38​
0​
-4.2​
3​
29​
19​
2.19​
-4​
195.88​
100​
98​
172.24​
0​
0​
4.16​
0​
0​
12.27​
0.21​
90​
2.64​
4518​
16.64​
0​
-4.2​
3​
29​
19​
2.18​
-4​
199.17​
100​
98​
172.331​
0​
0​
4.16​
0​
0​
12.05​
0.22​
90​
2.65​
4491​
16.64​
0​
-4.2​
1.5​
29​
18​
2.19​
-5.5​
198.76​
75.3​
98​
172.434​
0​
0​
4.1​
0​
0​
11.93​
0.03​
90​
2.51​
4561​
9.47​
0​
0​
17​
28​
18​
0.8​
0​
20.92​
6.7​
0​
172.523​
0​
0​
1.86​
0​
-0.8​
11.47​
-0.46​
90​
0.62​
4535​
0.77​
0​
0​
17​
28​
17​
0.24​
0​
8.51​
3.5​
0​
172.627​
0​
0​
1.66​
0​
0​
12.05​
0.17​
90​
0.19​
4338​
0.77​
0​
0​
17​
28​
17​
0.12​
0​
5.54​
2​
0​
172.722​
0​
0​
1.26​
0​
0​
12.73​
0.24​
90​
0.08​
4158​
0.77​
0​
0​
17​
28​
15​
0.11​
0​
1.15​
2.7​
0​
172.883​
0​
0​
1.22​
0​
0​
13.08​
0.29​
90​
0.04​
4011​
0.77​
0​
0​
17​
28​
8​
0.11​
0​
4.15​
2.7​
0​
172.936​
0​
0​
1.4​
0​
-0.8​
13.08​
0.3​
89​
0.07​
3817​
0.77​
0​
0​
17​
28​
0​
0.11​
0​
5.07​
2.7​
0​
173.016​
0​
0​
1.38​
0​
0​
13.42​
0.33​
89​
0.08​
3460​
0.77​
0​
0​
18.5​
28​
0​
0.11​
0​
4.42​
3.5​
0​
173.104​
0​
0​
1.44​
0​
-0.8​
13.88​
0.37​
89​
0.09​
3059​
1.28​
0​
0​
25.5​
27​
0​
0.36​
0​
30.23​
29.4​
0​
There is more but I cant upload the csv file and am limited on the number of characters in a post.
Have you pulled a plug out to see what they’re like . Nf fouls the plugs fairly quick when using it in every tank and will be more noticeable in high boost
No I have not but I will take a look, cheers
Maybe a remap for the fuel that is worse these days would sort it
It's. A good few years since it was mapped isn't it
