IDLE AIR CONTROL VALVE
conorob123
Member
Hi, i own a 2004 wrx it is idling very high around 1500rpm when hot and has engine light on. When plugged into it it says idle air control valve fault. I assume it is the idle air control valve itself so does Anybody have a idle air control valve for a 2004 blobeye wrx ej205? Closer to kerry the better but willing to travel
Hi. Did you try cleaning it and changing the gasket yet? Mine used to get clogged and a bit of a clean after taking it out resolved the issue. Worth a shot 👍
What did you use to clean it? Would something like Brake cleaner do?
Unless you have a new gasket there Don’t open it as the rubber gasket swells and it won’t fit back in so you will need a new 1 👍👍
Unless you don’t need to drive it 👍 then open away
Did you order 1 up there not expensive anyway
