Im selling my hydra ecu it came off an evo 3 but will fit any scooby no problem!
Here are some bits i found out about it:
8 Sequential Injector (High Current) and Ignition Outputs
32 x 32 High resolution Fuel and Ignition tables
Switchable Fuel and Ignition tables (32 x 32)
16 User Definable PWM Auxiliary Outputs
Internal 3 bar Map Sensor (5 Bar Optional)
Dual Knock Sensor inputs for closed loop control
Dedicated NTK Wide band Lambda input
Dual Closed Loop Narrow band Lambda control
9 Auxiliary inputs
Variable Camshaft Control (up to 4 Cams)
Drive By Wire Throttle (additional cost option)
Antilag
Launch Control
Dedicated outputs for standard Vehicle Instruments
Plug and Play applications for most Japanese vehicles
i have the evo 3 harness with it but if buying for another car a new harness will have 2 be got to fit that car!!!!
1000 ono
Phone or text 0877590730
9 Auxiliary inputs
Antilag
Launch Control
1000 ono
