Have you not got the fittings with the turbo ? An3 or 4 for the feed is fine , the return is just a steel pipe that should be with the turbo or is it going on a different engine ?
Hey @BazGF8 it's going onto another engine.
I have both fittings but the feed has the banjo so that's perfect but the return just has a sort of press on tube setup and I'd prefer to change that to a AN fitting
