Flemmers
Member
I guess I'll pop this up here for all you Subaru heads.
Hopefully gone before the weekend to someone who has experience with this.
A lot of interest already as expected she is a cracker of a car to be fair and generally spotless but she has a couple rust issues in the jacking points and along the skirts either side, front crossmember ideally needs doing too.
Boot is bone dry, along with the floor bed in good health.
Engine is bone dry and running 100%.
Built by Ali Burrows.
Small bubble appearing on driver side rear arch. To be honest you can barely see it until ya have your nose on it, but it's there.
Paintwork is pretty flawless besides and not as much as a ding in it.
Or at least I have yet to spot one.
But under the spoiler looks like it was welded on a bit rough but again ya wouldn't notice until your up against it.
Spec as follows
Northern Plate since 2008
("Cheap" VRT)
Only 2 previous owners.
2004 Subaru Impreza Sti Type Uk
*Stoker 2.1
*Head machined and polished
*Closed deck
*Upgraded head studs seals and gaskets
*Upgraded oil pump
*Upgraded fuel pump
*Upgraded valves
*Full engine rebuild top to bottom
*Full gear box rebuild
*Oil catch can
*New 3 port boost solenoid
*Safe map by Peter simms
*Steel rods
*Omega forged pistons
*2.5 crank
*Acl race bearings
*Rcm head gasket
*1050 injectors
*Precision turbo
*Stage 4 race clutch
*New 18" revolution alloys new tyres
*New flywheel
*New red manifold
*New u cradle
*New c cradles
*New arms
*New coilovers
*Turbo back full exhaust.
Was informed by someone who knew the car this was intended to break the 400 barrier but came up just short.
This was an Rkings win but unfortunately came without any build work or any service history or anything I have tried to get hold of it but no go.
Previous owner also had a folder of receipts but sold before the build happened.
Price €9000 or nearest offer
Send me a message on Whatsapp for any pics/vids of rust etc if they don't show up here.
0833599943
Spec as follows
("Cheap" VRT)
*Stoker 2.1
*Closed deck
*Upgraded oil pump
*Upgraded fuel pump
*Upgraded valves
*Oil catch can
*Steel rods
*2.5 crank
*Acl race bearings
*Rcm head gasket
*1050 injectors
*Precision turbo
*New flywheel
*New red manifold
*New u cradle
*New c cradles
*New arms
*New coilovers
0833599943
