2000 subaru legacy b4 . Need help
robbieb4
Need help
I bought a 2000 subaru legacy b4 2l twin turbo .
Was lying up a while ..its auto
The car starts up perfect and will rev no problem . Soon as I put it into drive or reverse the car revs very slow and has no power . It goes true the gears but drives very slow .
Anyone any ideas on wat it might be ..
I took of most sensors an checked an cleaned if possible . Also took of the intercooler and checked the turbos and actuators . . I'm gona put new plugs and air filter in it tomorrow.
Are the bars on the actuators ment to move when I rev the car .. as the ones on my turbos don't move at all . No mather how high I rev the car up . And are the 2 vacuum hoses that go to the actuators ment to have air coming out ov them .or do the suck . I also checked them while the car was ticking over plus been reved and there was no air coming from them . And they don't feel like they were sucking either. .
Welcome along đź‘Ť
Start with the checking the plugs and air filter . The actuators won’t move when just reved .
Ideally you’d need to do a smoke test as there’s the world of boost pipes there that could be cracked or perished .
When you say slow how slow .
The bars on the actuators don’t move until you’re on boost .
as Joe was saying maybe look at your plugs , coil packs , airflow meter .
Have you put fresh fuel in it ?
