Tx Jameswould be 99% its the same
Was fairly sure baz that just to mount the caliper that those brackets will mount both the WRX 2 pot and the gold brembo?Its not the same , Brembo uses a larger diameter disc 316mm where as the Subaru 2 pot use a 290mm disc
Its a bigger job after that then to run the brembo in terms of disc and handbrake shoes?
Personally I think the WRX 2 pot looks more age related than the Brembo on an early car too.
