Results 1 to 18 of 18
Thread: NCT emmissions
  1. #1
    Full ISDC Club Member mac mac's Avatar
    Jul 2007
    meath
    7,985
    10
    28
    NCT emmissions
    so had nct the other night and failed on emmissions and 1/2 other small things . but my query is in realation to the good old emmissions ,
    so off with the decat system and on with a no noise exhaust .
    so the high idle test says you have to be between 0.97 -1.03 , which has a window of jus 0.06 which in my mind is sounds like a pinhole rather than a window . my reading was 1.10 which is 0.07 outside the pinhole . {passed the low idle test )
    i had put some diptane to try and help bring emmisions down , but alas ,no joy.
    im jus finding it hard to understand why the window of pass is so small .
    any advice for retest is welcome to help try and get that magical trio of windscreen decorations .
    18 seconds !!
    Them wheels are ridicoulus , but they look class !
  2. #2
    Mar 2016
    88
    26
    3
    had problems on a twincam engine i built which was modified, she kept givng high HC no matter what! In the end i got fed up of trying to guess what made a difference and got the lend of a emissions tester.
    If you know anyone in a proper garage you could ask them for the lend of it, thats only way you'll know if your inside the small band for being OK. Dont waste your money getting a re-test when your unsure...
  3. #3
    Full ISDC Club Member seanie's Avatar
    Jul 2012
    Clare
    1,262
    17
    3
    10
    Your answer is in your question. Pinhole!
    High lambda on its own usually an exhaust leak.
    Window is so small because once your mixture is outside these limits production of unwanted byproducts NOx and SOx and similar exceed EU allowed limits
    We're CO and HC ok
    V5 STI TYPE R V-LIMITED
    BOB RAWLE MAPPED 346BHP/328FTLB
  4. #4
    Jul 2007
    meath
    7,985
    10
    28
    18 seconds !!
  5. #5
    Jul 2007
    meath
    7,985
    10
    28
    18 seconds !!
  6. #6
    Full ISDC Club Member Gary sti's Avatar
    Jan 2017
    Dublin
    2,210
    1,660
    17
    Did you have a small bit of bother last year with same part of test
    I remember asking when getting mapped and he said he check values on lambda that they are correct just a thought that’s all
  7. #7
    Full ISDC Club Member gttjohn's Avatar
    Dec 2010
    dublin
    618
    199
    2
    11
    I failed on emissions too I gave it new plugs oil and air filter and passed, I presume u probably did that next thing that worked on a 200sx for me was new lambda sensor well a lend of one anything is worth a shot
    8 mins 20 seconds or 186,000 miles a second
  8. #8
    Aug 2006
    5,245
    1
    19
    Leave it until the last minute, before test, drive the shite out of it and bring it in roasting hot.
  9. #9
    Member Number 2766
    ISDC Club Treasurer
    scoobysub's Avatar
    Nov 2008
    kilkenny
    12,010
    2,755
    1
    10
    Your lamba is on the way out spec c was the same last year was near the upper limit and swapped it out for a new 1 after the track day and I had the test yesterday and it was spot on 👍
  10. #10
    Dec 2010
    dublin
    618
    199
    2
    11
    yeah joe when i changed the lamda sensor it use much less fuel , get a lend of one of one of the lads if its that then buy a new one if mine fitted you could use mine
  11. #11
    Jul 2007
    meath
    7,985
    10
    28
    cheers for the replys and ideas , will investigate and try to see if they help get the pass on retest
    . pox bottle of a test .06 of a window, grrrr
    18 seconds !!
  12. #12
    Dec 2010
    dublin
    618
    199
    2
    11
    yeah man its like sitting an important test in collage it always puts the shits up me ,and then in the back of your mind im thinking are they trying to phase out powerfull jap cars fecking wonkers
  13. #13
    Member Number 161
    Full ISDC Members 2015
    keith dublin's Avatar
    Oct 2006
    Dublin
    17,318
    753
    57
    Ross mine was the same put the bung in and it passed something to do with drawing air back up the exhaust...
    Lad in the nct center said they sometimes block them off with cardboard to try get it right ....
  14. #14
    Member Number 161
    Oct 2006
    Dublin
    17,318
    753
    57
    Mine failed i ordered the bung retested 7 days later and it passed same machine was used to test it both times
    Then passed again this year with bung in
  15. #15
    Jul 2007
    meath
    7,985
    10
    28
    hmmmm intresting , possibly worrh a try ,
    18 seconds !!
  16. #16
    Member Number 161
    Oct 2006
    Dublin
    17,318
    753
    57
    I have a bung here you can have a lend if you want 4"
  17. #17
    Jul 2007
    meath
    7,985
    10
    28
    i have a bung aswell for my kakimoto but it is about 5mm too small for current backbox, which looks/reminds me of the s202 with "sti" on side of it .
    18 seconds !!
  18. #18
    Member Number 2766
    ISDC Club Treasurer
    scoobysub's Avatar
    Nov 2008
    kilkenny
    12,010
    2,755
    1
    10
    S202 you say
