Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Slight clunking noise on roundabouts and now starting on straights
  1. #1
    Full ISDC Club Member gttjohn's Avatar
    Join Date
    Dec 2010
    Location
    dublin
    Posts
    573
    Thanks
    189
    Rides
    2
    Rep Power
    11
    Hi guys any ideas I hear a slight clunking noise on entry and exits from motorways at speed and roundabouts it's still there when I clutch its still there it's barely noticeable on the straight what could it be, I thought it might be a wheel bearing but no movement from wheels With car jacked up, any ideas or ways of diagnosis thanks again guys
    8 mins 20 seconds or 186,000 miles a second
  2. #2
    Committe Members Ciaran WRX's Avatar
    Join Date
    Jan 2013
    Location
    Ireland
    Posts
    12,106
    Thanks
    4,782
    Rides
    1
    Rep Power
    60
    Have a look at your drop links Uasual culprit
  3. #3
    Join Date
    Dec 2010
    Location
    dublin
    Posts
    573
    Thanks
    189
    Rides
    2
    Rep Power
    11
    Also the clunking speeds up with speed, I'm sure it's not engine as noise speeds up and slows down regardless if the clutch is engaged
  4. #4
    Join Date
    Dec 2010
    Location
    dublin
    Posts
    573
    Thanks
    189
    Rides
    2
    Rep Power
    11
    Realy would that cause that I'm amazed
  5. #5
    Full ISDC Club Member przemcio007's Avatar
    Join Date
    Jun 2013
    Location
    Arklow
    Posts
    1,204
    Thanks
    126
    Rides
    0
    Rep Power
    11
    Either drop links as Ciaran said or ball joints. Cheap in both scenarios to fix.
    Hold my beer. 'll show you how to do it :-D
  6. #6
    Join Date
    Jan 2013
    Location
    Ireland
    Posts
    12,106
    Thanks
    4,782
    Rides
    1
    Rep Power
    60
    Have a look at em John if look past it prob are cheap thing to rule out anyway oem cheap to do anyway
  7. #7
    Join Date
    Dec 2010
    Location
    dublin
    Posts
    573
    Thanks
    189
    Rides
    2
    Rep Power
    11
    What's em lads, also who would u leave it with to diagnose and repair it be a shame to change a heap of bits if only two need replacing thanks again, does a cv joint clunk at speed I always though it was a slow speed full lock test for that
  8. #8
    Join Date
    Jan 2013
    Location
    Ireland
    Posts
    12,106
    Thanks
    4,782
    Rides
    1
    Rep Power
    60
    Em = Them meaning droplinks
  9. The Following User Says Thank You to Ciaran WRX For This Useful Post:
    gttjohn (07-08-2018)
  10. #9
    Member Number 2766
    ISDC Club Treasurer
    scoobysub's Avatar
    Join Date
    Nov 2008
    Location
    kilkenny
    Posts
    11,959
    Thanks
    2,702
    Rides
    1
    Rep Power
    10
    If it goes with the speed it's not the droplinks is it your brakepads or a heat shield rubbing
    colin, richard, bertie, frank, gone but not forgotten.
    Peter marks account Reopened in Style!!!
  11. #10
    Join Date
    Dec 2010
    Location
    dublin
    Posts
    573
    Thanks
    189
    Rides
    2
    Rep Power
    11
    But a clunking noise, a shield would have a metallic sound
  12. #11
    Member Number 935
    Full ISDC Members 2015
    tommy 555's Avatar
    Join Date
    Sep 2007
    Location
    wicklow
    Posts
    12,286
    Thanks
    555
    Rides
    1
    Rep Power
    42
    Did you check the tires to make sure something isn't trapped in the threads
    Built By Ali ,,,,,, Mapped By Bob,,,,,, Driven by Tommy ,,,, 2006 STi
  13. #12
    Join Date
    Aug 2017
    Posts
    390
    Thanks
    320
    Rides
    0
    Rep Power
    5
    Worth checking your arb bushes and your top hat bolts too
  14. #13
    Join Date
    Dec 2010
    Location
    dublin
    Posts
    573
    Thanks
    189
    Rides
    2
    Rep Power
    11
    Checked the tyres nothing in them pushed the heat shields back, top mount nuts fine could it be a wheel bearing ,or as you guys said some bushing Ahh I'm Gona drive it a bit longer and see if reveals it's self as it might get noisier, Ahh it's just a pain in the balls when ever u drive it and it's not proper
  15. #14
    Full ISDC Club Member DaveSleggy's Avatar
    Join Date
    Jan 2013
    Location
    Dublin
    Posts
    2,063
    Thanks
    623
    Rides
    1
    Rep Power
    18
    I had a wheel bearing go in mine and there was a rubbing/grinding noise like a seized caliper or something rubbing on the disk. There was zero play in the wheel itself as apparently Subaru wheel bearings dont show too much wobble until they fail badly.
  16. #15
    Full ISDC Club Member Gary sti's Avatar
    Join Date
    Jan 2017
    Location
    Dublin
    Posts
    2,144
    Thanks
    1,594
    Rides
    0
    Rep Power
    16
    I have my two rears done they where making a grinding crunching noise the track day really finished them off like you say John gets more noticeable when turning corners with weight shifting replace as a pair
  17. #16
    Full ISDC Club Member CARLO's Avatar
    Join Date
    Jul 2006
    Location
    Dark side ot the moon
    Posts
    4,589
    Thanks
    278
    Rides
    0
    Rep Power
    18
    Stone in caliper????
    Whats that comming over the hill
  18. #17
    Join Date
    Dec 2010
    Location
    dublin
    Posts
    573
    Thanks
    189
    Rides
    2
    Rep Power
    11
    I'm going to check everything. But somthing is telling me it might be the front differential ,I hope it isn't, could end up rwd conversion
  19. #18
    Join Date
    Dec 2010
    Location
    dublin
    Posts
    573
    Thanks
    189
    Rides
    2
    Rep Power
    11
    Larkin automotive very nice place
    Well I left the subaru in with Larkin automotive this morning and asked them to check everything and if it needs replacing please do it, they seam realy nice and effortless to work with ,mind a few nice cars there one silver English reg subaru in particular OMG, Ahh well I'll just wait till I have my thunder bus back, I have the wife's qashqai nice ride but dead
  20. The Following 3 Users Say Thank You to gttjohn For This Useful Post:
    Ciaran WRX (14-08-2018), hassen27 (14-08-2018), scoobysub (16-08-2018)
  21. #19
    Join Date
    Jan 2013
    Location
    Ireland
    Posts
    12,106
    Thanks
    4,782
    Rides
    1
    Rep Power
    60
    Ciaran Larkin is a gent great setup there
  22. #20
    Full ISDC Club Member hassen27's Avatar
    Join Date
    Aug 2016
    Location
    Loughlinstown, Dublin
    Posts
    1,193
    Thanks
    1,193
    Rides
    1
    Rep Power
    10
    Quote Originally Posted by gttjohn View Post
    Ciaran and the lads did all the work on my car. You're in good hands.
    Silver blob S203 there is immaculate. Also there's was blue blob Jdm twin scroll last time I was there. My car was in good company
    #hmblwgn
    www.instagram.com/hhphoto7
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
