Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Slight clunking noise on roundabouts and now starting on straights
  1. #1
    Full ISDC Club Member gttjohn's Avatar
    Dec 2010
    dublin
    515
    140
    2
    10
    Hi guys any ideas I hear a slight clunking noise on entry and exits from motorways at speed and roundabouts it's still there when I clutch its still there it's barely noticeable on the straight what could it be, I thought it might be a wheel bearing but no movement from wheels With car jacked up, any ideas or ways of diagnosis thanks again guys
    8 mins 20 seconds or 186,000 miles a second
  2. #2
    Committe Members Ciaran WRX's Avatar
    Jan 2013
    Ireland
    12,006
    4,728
    1
    59
    Have a look at your drop links Uasual culprit
  3. #3
    Dec 2010
    dublin
    515
    140
    2
    10
    Also the clunking speeds up with speed, I'm sure it's not engine as noise speeds up and slows down regardless if the clutch is engaged
  4. #4
    Dec 2010
    dublin
    515
    140
    2
    10
    Realy would that cause that I'm amazed
  5. #5
    Full ISDC Club Member przemcio007's Avatar
    Jun 2013
    Arklow
    1,186
    121
    11
    Either drop links as Ciaran said or ball joints. Cheap in both scenarios to fix.
    Hold my beer. 'll show you how to do it :-D
  6. #6
    Jan 2013
    Ireland
    12,006
    4,728
    1
    59
    Have a look at em John if look past it prob are cheap thing to rule out anyway oem cheap to do anyway
  7. #7
    Dec 2010
    dublin
    515
    140
    2
    10
    What's em lads, also who would u leave it with to diagnose and repair it be a shame to change a heap of bits if only two need replacing thanks again, does a cv joint clunk at speed I always though it was a slow speed full lock test for that
  8. #8
    Jan 2013
    Ireland
    12,006
    4,728
    1
    59
    Em = Them meaning droplinks
  9. The Following User Says Thank You to Ciaran WRX For This Useful Post:
    gttjohn (07-08-2018)
  10. #9
    Member Number 2766
    ISDC Club Treasurer
    scoobysub's Avatar
    Nov 2008
    kilkenny
    11,848
    2,562
    1
    10
    If it goes with the speed it's not the droplinks is it your brakepads or a heat shield rubbing
  11. #10
    Dec 2010
    dublin
    515
    140
    2
    10
    But a clunking noise, a shield would have a metallic sound
  12. #11
    Member Number 935
    Full ISDC Members 2015
    tommy 555's Avatar
    Sep 2007
    wicklow
    12,204
    555
    1
    40
    Did you check the tires to make sure something isn't trapped in the threads
    Built By Ali ,,,,,, Mapped By Bob,,,,,, Driven by Tommy ,,,, 2006 STi
  13. #12
    Full ISDC Club Member Fozzy's Avatar
    Aug 2017
    371
    313
    4
    Worth checking your arb bushes and your top hat bolts too
  14. #13
    Dec 2010
    dublin
    515
    140
    2
    10
    Checked the tyres nothing in them pushed the heat shields back, top mount nuts fine could it be a wheel bearing ,or as you guys said some bushing Ahh I'm Gona drive it a bit longer and see if reveals it's self as it might get noisier, Ahh it's just a pain in the balls when ever u drive it and it's not proper
  15. #14
    Full ISDC Club Member DaveSleggy's Avatar
    Jan 2013
    Dublin
    2,059
    616
    1
    18
    I had a wheel bearing go in mine and there was a rubbing/grinding noise like a seized caliper or something rubbing on the disk. There was zero play in the wheel itself as apparently Subaru wheel bearings dont show too much wobble until they fail badly.
  16. #15
    Full ISDC Club Member Gary sti's Avatar
    Jan 2017
    Dublin
    2,025
    1,454
    15
    I have my two rears done they where making a grinding crunching noise the track day really finished them off like you say John gets more noticeable when turning corners with weight shifting replace as a pair
  17. #16
    Full ISDC Club Member CARLO's Avatar
    Jul 2006
    Dark side ot the moon
    4,578
    263
    18
    Stone in caliper????
    Whats that comming over the hill
  18. #17
    Dec 2010
    dublin
    515
    140
    2
    10
    I'm going to check everything. But somthing is telling me it might be the front differential ,I hope it isn't, could end up rwd conversion
  19. #18
    Dec 2010
    dublin
    515
    140
    2
    10
    Larkin automotive very nice place
    Well I left the subaru in with Larkin automotive this morning and asked them to check everything and if it needs replacing please do it, they seam realy nice and effortless to work with ,mind a few nice cars there one silver English reg subaru in particular OMG, Ahh well I'll just wait till I have my thunder bus back, I have the wife's qashqai nice ride but dead
  20. The Following 3 Users Say Thank You to gttjohn For This Useful Post:
    Ciaran WRX (14-08-2018), hassen27 (14-08-2018), scoobysub (16-08-2018)
  21. #19
    Jan 2013
    Ireland
    12,006
    4,728
    1
    59
    Ciaran Larkin is a gent great setup there
  22. #20
    Full ISDC Club Member hassen27's Avatar
    Aug 2016
    Loughlinstown, Dublin
    1,147
    1,135
    1
    10
    Quote Originally Posted by gttjohn View Post
    Ciaran and the lads did all the work on my car. You're in good hands.
    Silver blob S203 there is immaculate. Also there's was blue blob Jdm twin scroll last time I was there. My car was in good company
    #hmblwgn
    www.instagram.com/hhphoto7
