Jdm bl5 standard unit working
gttjohn
I bought it on adverts for buttons and fitted it it works perfectly cds stereo ac, I'm very happy just plug an play, it's the standard unit from a broke legacy
Ahh well that didn't last long the stereo turns it's delve off after a couple of mins the radios are car specific what a mick in the kicky. Is there any way to bypass the security on these, as my cd now won't accept cds it spits them back out (original )
Stereo how do you fix that I'm using a radio transmitter connected to my phone to listen to the radio or tunes on the phone, any thoughts lads
Is there a double din kit available so that you can put an aftermarket unit instead John? I know it would be nice to have the oem unit, but the advantages of a newer hu are much easier to live with [emoji4]
#hmblwgn
www.instagram.com/hhphoto7
That's true. You'd only have to buy the facia suitable for your car to fit a double din.
You'd get rid of a lot of the heartache. And have better sound output etc
Its expensive to go the double din route on the bl5 since the aircon controls are part of the headunit assembly. You can get a fascia kit from subaru thats rather expensive, or you can put a single din in between the aircon vents on the dash
My old top setup:
https://youtu.be/ARE1ykxMIRk
Double din kit here:
older first headunit i had:
If my old build there is in the members section there should be loads of info in it and whats needed to make it work
Yeah I have been looking around for the kit it's about 250 -300 Euro then you need the head unit, that can I suppose what ever price
You want, see where you had the h/u up top there Dan I put a screen and reverse camera dognabbit nothing easy with the legacys, thanks lads for the replies
