Results 1 to 4 of 4
Thread: 2000 Legacy B4 JDM rev C Manual full dashboard and instrument cluster replacement
  1. #1
    Junior Member
    Jul 2014
    5
    Post 2000 Legacy B4 JDM rev C Manual full dashboard and instrument cluster replacement
    Hi,
    my 2000 Legacy B4 (Rev C, manual, sedan) needs whole dashboard and instrument cluster to be replaced due to fire damage.
    Please see attached photos.
    Full dashboard with all wiring:
    Instrument cluster
    The part of wire loom and instrument cluster just melted. The rest of the loom looks to be good. I will test it, but there is no visual signs of heat/fire damage.
    Question:
    Can i get dash and instrument cluster from any revision or only rev C?
    Also, how can i get odometer reading to get adjusted on new (2nd hand) instrument cluster?
  2. #2
    Junior Member
    Jul 2014
    5
    update
    the man from Subaru dealer cross checked the dash and wiring loom from revision C model with automatic transmission and said it is the same as manual rev C.
    In progress of finding the dash and instrument cluster now
  3. #3
    Full ISDC Club Member dontommy's Avatar
    Aug 2009
    Clonmel
    7,844
    5,958
    51
    They are very hard to find but there is a very $€xy zerosport cluster for legacy with 300km deal and 10k rev
    Attached Images Attached Images
  4. #4
    Junior Member
    Jul 2014
    5
    Quote Originally Posted by dontommy View Post
    I got dash with wiring loom and instrument cluster from rev C with automatic transmission.
    It should be all right, because fellow subaru owner used instrument cluster from manual to the automatic and it works (manual ecu was used in automatic transmission body)
