Results 1 to 9 of 9
Thread: Spoiler bolts
  1. #1
    Member Number 161
    Full ISDC Members 2015
    keith dublin's Avatar
    Join Date
    Oct 2006
    Location
    Dublin
    Posts
    17,160
    Thanks
    730
    Rides
    0
    Rep Power
    56
    Spoiler bolts
    Been getting a rust water mark coming from the rear spoiler water drain holes ..turns out the slide bolts in the spoiles are rusted so need replacing...has anyone done this im looking for all the bolts and the spong sticking pads that go on as well...
    Anyone know where they can be got ...or links to new parts
    Cheers k
    IT TOOK ME FOOKING 3 YEARS TO WORK OUT HOW TO PUT THIS SMALL BIT OF TEXT HERE!!!!!
  2. #2
    Member Number 935
    tommy 555's Avatar
    Join Date
    Sep 2007
    Location
    wicklow
    Posts
    12,139
    Thanks
    555
    Rides
    1
    Rep Power
    39
    Same issue happening on mine . Starting to bug me a bit now
    Built By Ali ,,,,,, Mapped By Bob,,,,,, Driven by Tommy ,,,, 2006 STi
  3. #3
    Member Number 25
    DUFFMAN's Avatar
    Join Date
    Jul 2006
    Location
    Dublin
    Posts
    7,015
    Thanks
    586
    Rides
    0
    Rep Power
    25
    C@R have them Keith
    I got some from them before
    as Marcus Gronholm once said "up the arse of timo"...
  4. #4
    Full ISDC Club Member Gary sti's Avatar
    Join Date
    Jan 2017
    Location
    Dublin
    Posts
    1,925
    Thanks
    1,301
    Rides
    0
    Rep Power
    14
    I have had mine off and got boot lid redone on the wing I stripped off all the old sponge and when put it back on i used 3 mm window gasket the sponge wares out and wing starts vibrating hence damaging boot lid aswell get the rubber discs that go on wing to stop water leaking into boot as I do get a small drip sometimes hopefully this helps
  5. #5
    Member Number 161
    Join Date
    Oct 2006
    Location
    Dublin
    Posts
    17,160
    Thanks
    730
    Rides
    0
    Rep Power
    56
    Cherrs lads what are the discs gary where do the go
  6. #6
    Join Date
    Jan 2017
    Location
    Dublin
    Posts
    1,925
    Thanks
    1,301
    Rides
    0
    Rep Power
    14
    Quote Originally Posted by keith dublin View Post
    They where on the underside of wing to seal to boot lid when tightened down to stop water leaking through holes I would say the rusty water mark would nearly buff out on a lot of it
  7. #7
    Join Date
    Jan 2017
    Location
    Dublin
    Posts
    1,925
    Thanks
    1,301
    Rides
    0
    Rep Power
    14
    A rubber washer
  8. #8
    Member Number 3801
    Join Date
    Aug 2010
    Location
    Meath
    Posts
    3,255
    Thanks
    257
    Rides
    0
    Rep Power
    14
    A fallout remover/IronX and decent clay bar will remove the rust marks from the paint work Keith. No need to be too abrasive.
  9. #9
    Member Number 161
    Join Date
    Oct 2006
    Location
    Dublin
    Posts
    17,160
    Thanks
    730
    Rides
    0
    Rep Power
    56
    Cheers john ill try that as soon as i change the bolts
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
