Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: 99 WRX import remap
  1. #1
    Full ISDC Club Member flat4hore's Avatar
    Aug 2008
    Wicklow
    44
    14
    Wink 99 WRX import remap
    Hey folks,
    Ok so I recently purchased a clean 99 WRX as a weekend toy, it has forged engine with a VF29 turbo, standard exhaust and ecu
    There was a full decat on the car with equal length manifold but it was way too loud for my liking so the original standard exhaust is back on. As the car sits now what are my options for remapping? And what cost can I expect?
    The check engine light comes on under hard acceleration but goes off again after a few mins...
    Any info would be great.
  2. #2
    Full ISDC Club Member Jarocki's Avatar
    Jul 2016
    Dublin
    303
    8
    3
    Get onto Aunghus Power in Galway to remap your car. Will spend the whole day on it. Prob looking at around 400 - 500 euro if he can may the standard ECU.
  3. The Following User Says Thank You to Jarocki For This Useful Post:
    flat4hore (23-05-2018)
  4. #3
    Webmaster SCOOBYCOLM's Avatar
    Jan 2009
    Dublin
    20,649
    4,411
    2
    10
    Your check engine light might be a knock sensor
    But it could be several things
    just be careful its not a failing MAF
    Check for fault codes via the connectors below the dash
    you can see how to do that here
    I dont think Aounghus does the classic stock ecu
    I dont think the v5/v6 ecu can be remapped via open source so You would need a ECUTEK remap afaik
    Ask Dave in RSR Automotive I think he does them
    Has the car been remapped already ?
    Dashcam Sales & Installation www.dashcam.ie
  5. The Following User Says Thank You to SCOOBYCOLM For This Useful Post:
  6. #4
    Aug 2008
    Wicklow
    44
    14
    Quote Originally Posted by SCOOBYCOLM View Post
    As far as I know the car hasn't been mapped, was just worried because the exhaust is standard that it be a fecker to map etc...
  7. #5
    Junior Member
    Mar 2015
    Belfast
    24
    2
    standard exhaust is no issue for mapping, just means you won't get as much gains from it - you'll already be losing out because of 95 fuel so the normal way to go is fuel pump, panel filter, exhaust and remap to suit.
    for remapping you can go with ECUTek or ECULabs options, I prefer ECUTek if your not planning to do much to the car and ECULabs if your planning to add more bits later or you fancy a bit of the old antilag action (though you'll not be hearing much on the standard exhaust to be fair).
  8. The Following User Says Thank You to bludgod For This Useful Post:
    SCOOBYCOLM (24-05-2018)
  9. #6
    Commitee Member / ISDC Event Organizer GORDON GT SERIES II's Avatar
    Mar 2008
    offaly
    7,048
    1,624
    1
    32
    V5/v6 on ecu can be open source mapped so is another option for you
    Sent from my SM-G930F using Tapatalk
  10. #7
    Jan 2009
    Dublin
    20,649
    4,411
    2
    10
    what mapping software is used for that Gordon
  11. #8
    Mar 2008
    offaly
    7,048
    1,624
    1
    32
    I'm not too sure colm but fairly sure it can be done I remember someone telling me before that there's more options than just ecutek, aonghus possibly can do it but again I could be wrong on both
  12. #9
    Sep 2017
    50
    25
    1
    I would drive it real easy untill you get it mapped. Engine light likely picking up detonation so if I was you id get it mapped for 95 ron asap .. aonghus will do a mighty job if you have a mapable ecu
  13. #10
    Aug 2008
    Wicklow
    44
    14
    Quote Originally Posted by Prodrive555 View Post
    Would stock injectors be ok or will I upgrade to yellow?I have 4 yellow from few years back sittin in a box...also is a sport cat worth getting? I have a silent hi power exhaust sittin in a box also but want to look into sport cats etc
  14. #11
    Mar 2008
    offaly
    7,048
    1,624
    1
    32
    Quote Originally Posted by flat4hore View Post
    Afaik it should have 440 injectors already
  15. The Following User Says Thank You to GORDON GT SERIES II For This Useful Post:
    flat4hore (27-05-2018)
  16. #12
    Junior Member
    Mar 2015
    Belfast
    24
    2
    should be grand on the 440's you have unless your looking at a bigger turbo. As far as I know there's no opensource option for v5/v6 has to be ECUTek or ECULabs if you want to use the standard ECU. Apexi still a solid option for them as well if you can find one second hand for decent money.
  17. #13
    Aug 2008
    Wicklow
    44
    14
    Quote Originally Posted by bludgod View Post
    Well for now I just want it mapped for what's on it...I have ordered a hks silent hi power cat back and I'm in two minds about a sports cat...I have a walboro pump and panel filter ready to go on...the turbo is a VF29 also... it runs a little rough on idle also
    Sent from my SM-N950F using Tapatalk
    97 Impreza STI Type R V4
    95 Impreza STI 2.5 prodrive
    98 Impreza Turbo 2000
    00 Impreza Turbo 2000
    93 Impreza WRX STI V1
    99 Impreza WRX
  18. #14
    Junior Member
    Mar 2015
    Belfast
    24
    2
    the rough idle is probably related to the engine light flashing at you so get that checked out first, no point trying to dial the car in with the laptop if there are faults lurking as it will only cause problems later.
  19. The Following User Says Thank You to bludgod For This Useful Post:
    flat4hore (29-05-2018)
  20. #15
    Aug 2008
    Wicklow
    44
    14
    Will the fault be readable if the light is off? It only comes on if you start boosting..I drove it to nct centre yesterday and it passed no problems..engine light hasn't come on in a few days now
    99 Impreza WRX
  21. #16
    Full ISDC Club Member Fozzy's Avatar
    Aug 2017
    327
    300
    3
    I’d imagine its your knock sensor that’s causing the light, sensing detonation under boost. If you add some octane booster until you get it mapped it should help out a bit with knock - that said, I’d be taking it fairly handy until I got it mapped.
  22. The Following User Says Thank You to Fozzy For This Useful Post:
  23. #17
    Aug 2008
    Wicklow
    44
    14
    Quote Originally Posted by Fozzy View Post
    Yep i hardly take it past 3k rpm just waiting for a price from Robbie (TDP) for a price on remap...il get it in asap
    99 Impreza WRX
  24. #18
    Apr 2016
    Dublin
    7
    4
    Rolling Road
    Have been looking for someone to map my 2004 Legacy Spec B Gt for 95RON and Aunghus's name seems to keep appearing. Does he have a dyno for maps or does he work on the road? Thanks in advance
  25. #19
    Full ISDC Club Member Pedro555's Avatar
    Nov 2013
    clare
    2,618
    2,378
    20
    Quote Originally Posted by danielknocker View Post
    Has a dyno, then brings you for a spin on the road to make sure all is good
    Subaru Impreza WRX STI Type R -Version 4 V Limited
  26. The Following User Says Thank You to Pedro555 For This Useful Post:
    danielknocker (29-05-2018)
  27. #20
    Apr 2016
    Dublin
    7
    4
    Quote Originally Posted by Pedro555 View Post
    Thanks for the reply, Any chance someone could point me in the direction of his contact details?
  28. The Following User Says Thank You to danielknocker For This Useful Post:
    Pedro555 (29-05-2018)
