Results 1 to 10 of 10
Thread: Turbo Blankets....
  1. #1
    Committe Members Ciaran WRX's Avatar
    Join Date
    Jan 2013
    Location
    Ireland
    Posts
    12,103
    Thanks
    4,782
    Rides
    1
    Rep Power
    60
    Turbo Blankets....
    What's the general opinion here on them
    Various stuff out there in internet land some good some bad
    Some say will need map tweek some say won't ect
    Basically have one here and wondering what's the general experiences from lads
    Cheers
  2. #2
    Full ISDC Club Member hassen27's Avatar
    Join Date
    Aug 2016
    Location
    Loughlinstown, Dublin
    Posts
    1,193
    Thanks
    1,193
    Rides
    1
    Rep Power
    10
    That's just pure filth! Drool! Love how even the box is so nicely sorted.
    I think the blanket will improve things a bit. How much, that I am not sure but it can't hurt the performance :)
  3. #3
    Join Date
    Jan 2013
    Location
    Ireland
    Posts
    12,103
    Thanks
    4,782
    Rides
    1
    Rep Power
    60
    Fairly Filthy alright
  4. #4
    Member Number 25
    Full ISDC Members 2015
    DUFFMAN's Avatar
    Join Date
    Jul 2006
    Location
    Dublin
    Posts
    7,054
    Thanks
    623
    Rides
    0
    Rep Power
    25
    Can't see why it would need a tweek map Ciaran.
    It's only a heat shield at the end of the day like the standard one.
    I'm going for one soon on my track car, if your not going to use it give me a buzz
    as Marcus Gronholm once said "up the arse of timo"...
  5. The Following User Says Thank You to DUFFMAN For This Useful Post:
    Ciaran WRX (10-05-2018)
  6. #5
    Join Date
    Aug 2006
    Location
    dublin 24
    Posts
    1,780
    Thanks
    15
    Rides
    0
    Rep Power
    19
    Probually the only bad point is it won't let the heat of the turbo itself get dispersed, but will keep the temps in the engine bay down a tad.
    Had a turbo, WRX , STI , 2 WR1s and a legacy B4
    What's left?........Litchfield T25
  7. #6
    Join Date
    Mar 2016
    Posts
    124
    Thanks
    0
    Rides
    0
    Rep Power
    3
    I have one on my car. There are two areas that you gain
    1. The heat coming of the turbine housing as you know is a lot. By adding the blanket you are keeping a lot of that heat away from parts like intercooler and rubber pipes. The compressor housing I found stays cooler. My big issue was intercooler. I run the top mount and found that the IC would get hot on the turbo side when parked off. With the blanket it has taken away a lot of that heat, not all but a massive difference.
    2. By holding the heat it helps with turbo spool, so keeping the turbine hot and not letting the heat escape is a good thing. More heat more energy.
    You diffidently do not need to map the car. My advise if you have it use it. However its not the easiest thing to fit.
  8. The Following User Says Thank You to scoobySteve For This Useful Post:
    hassen27 (11-05-2018)
  9. #7
    Join Date
    Aug 2006
    Posts
    339
    Thanks
    9
    Rides
    0
    Rep Power
    13
    good job
    great job .. keeping engine bay temps down is a must ..
    the hotter the exhaust gas the faster it flows ...
    www.aliburrowsmotorsport.com
  10. #8
    Full ISDC Club Member Eoinmack's Avatar
    Join Date
    May 2016
    Location
    Limerick
    Posts
    1,336
    Thanks
    981
    Rides
    1
    Rep Power
    9
    Might look into getting one of these myself. Car is missing the turbo heat shield since I got it, would brands play a big part here?
  11. #9
    Join Date
    Aug 2016
    Location
    Posts
    1,193
    Thanks
    1,193
    Rides
    1
    Rep Power
    10
    Quote Originally Posted by Eoinmack View Post
    Cheaper options available and do make a difference. Pain to install.
  12. #10
    Join Date
    May 2016
    Location
    Limerick
    Posts
    1,336
    Thanks
    981
    Rides
    1
    Rep Power
    9
    I'd imagine so, bit of a tight spot lol
    Yeah I seen there was few cheap things alright..but wouldn't imagine they'd hold up too long. But on the other hand, a blanket is a blanket like... perrin or the likes..they all the same really id imagine
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
