SC46 Turbo
BazGF8
OG Wagan
Selling this as I’m upgrading, still on the car so you can see running , no smoke etc . There is approximately 20,000km on the turbo.
Originally specced for a 2 litre engine for another member on here ,so has a 7cm exhaust housing
It’s a billet ball bearing unit
The core is essentially a garret GT3071 with exhaust and compressor housings machined by Blouch Turbos in the USA to create a bolt on factory position turbo capable of 400hp+ (engine spec and fuel dependent)
Scoobyclinic in the Uk market these as their own turbo the SC46
Max boost the turbo has seen is 1.3bar but is capable of more.
On a 2.5 I’m getting full boost at 3000rpm
Comes with oil line and every thing needed to fit
€950
