Results 1 to 3 of 3
Thread: Jdm I/C Install to wrx advice
  1. #1
    Committe Members Ciaran WRX's Avatar
    Join Date
    Jan 2013
    Location
    Ireland
    Posts
    12,201
    Thanks
    4,851
    Rides
    1
    Rep Power
    61
    So got a ic kit I was after for a while nice neat one in bay and should be nice neat install as my top mount got the nozzels built into it
    Any advice on the best way to wire it up the auto function would be handy
    bit online bit most are Diy bodge jobs like it right
    Cheers
  2. #2
    Join Date
    Aug 2006
    Posts
    5,246
    Thanks
    1
    Rides
    0
    Rep Power
    19
    It was controlled originally by ECU which was using MAP readings to control on and off.... so you can replicate this without using the ECU basically and can set up a pressure sensor off inlet manifold so for talks sake when boost hits 7psi + spray will be activated and deactivate when boost drops below that threshold it switches off.
    Tbh with you, I have never ever seen the water spray make a difference in any car I had it in, and this is only my view but I would suspect if you spent a bit of time and thought on getting cooler air from outside into the filter, and if an open induction filter keeping the hot air away from it.... it would be just about if not more beneficial.
  3. #3
    Join Date
    Jan 2013
    Location
    Ireland
    Posts
    12,201
    Thanks
    4,851
    Rides
    1
    Rep Power
    61
    Quote Originally Posted by KENC View Post
    Thanks Ken
    I'll look into that
    Know what your saying just something I wanted in car and as top mount has the nozzels ect
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
