Results 1 to 15 of 15
Thread: Legacy Heater problems
  1. #1
    Full ISDC Club Member
    Join Date
    Jan 2017
    Posts
    16
    Thanks
    0
    Rides
    0
    Rep Power
    0
    Unhappy Legacy Heater problems
    Guys/Gals
    I have a 2010 legacy Estate .
    Have problem in that the heater has stopped working on passenger side .
    No matter how high heater is set there is only heat coming out on drivers side non on passenger .
    Doesn't matter if dual heat turned on or off .
    Been told it is probably a big job involving removing dash to get in to actual matrix .
    Has anyone had similar issues and if so did you get it sorted and how.
    Would a heater flush work ?
    I am not certain if it is matrix or some of the actuators ?
    Thoughts folks ??
  2. #2
    Join Date
    Jan 2017
    Posts
    16
    Thanks
    0
    Rides
    0
    Rep Power
    0
    Folks
    Anyone got any suggestions about my question ?
    Quote Originally Posted by Geds View Post
    Guys/Gals
    Thoughts folks ??
  3. #3
    Join Date
    Aug 2017
    Posts
    390
    Thanks
    320
    Rides
    0
    Rep Power
    5
    Try back flush the heater coil. disconnect both lines and using a garden hose and very hot water, flush the coil - do it in both directions and about a dozen times - sometimes crud can clog the passenger side of the coil.
    There’s also an actuator for the passenger side mix which can act up
  4. #4
    Member Number 2766
    ISDC Club Treasurer
    scoobysub's Avatar
    Join Date
    Nov 2008
    Location
    kilkenny
    Posts
    12,063
    Thanks
    2,810
    Rides
    1
    Rep Power
    10
    As Far as I know the matrix is a single unit so if it's working on the drivers side it's not opening up on the passengers side . Is there any Air at all blowing out or just cold air
    colin, richard, bertie, frank, gone but not forgotten.
    Peter marks account Reopened in Style!!!
  5. #5
    Join Date
    Jan 2017
    Posts
    16
    Thanks
    0
    Rides
    0
    Rep Power
    0
    Just cold out of passenger , hot from drivers side but even that is not roasting
  6. #6
    Full ISDC Club Member seanie's Avatar
    Join Date
    Jul 2012
    Location
    Clare
    Posts
    1,270
    Thanks
    17
    Rides
    3
    Rep Power
    10
    it is the heater flap control motor on passenger side is your problem
    V5 STI TYPE R V-LIMITED
    BOB RAWLE MAPPED 346BHP/328FTLB
  7. #7
    Join Date
    Jan 2017
    Posts
    16
    Thanks
    0
    Rides
    0
    Rep Power
    0
    Going to try the flushing to see if that works .
    If not is getting at the acctuator a pain?
    Any links to show where and how ??
  8. #8
    Join Date
    Jan 2017
    Posts
    16
    Thanks
    0
    Rides
    0
    Rep Power
    0
    Quote Originally Posted by seanie View Post
    Seanie,
    I don't know yet . Any tips on how I would check
  9. #9
    Join Date
    Jul 2012
    Location
    Clare
    Posts
    1,270
    Thanks
    17
    Rides
    3
    Rep Power
    10
    looks something like this, have not replaced on subaru but have on countless other breeds.
    remove or fold down glovebox and look at side of centre console behind radio and heater controls should be there, disconnect motor and see if you get heat when manually activated, should diagnose your problem
    Attached Images Attached Images
  10. #10
    Join Date
    Jan 2017
    Posts
    16
    Thanks
    0
    Rides
    0
    Rep Power
    0
    Think I will try the flush first sometime over next few weeks .
    If that doesn't help them go looking at the other suggestions .
    Would be handy if Haynes or someone did a manual for it .
    I haven't been able to find one .
    Does such a manual exist ?
  11. #11
    Join Date
    Jul 2012
    Location
    Clare
    Posts
    1,270
    Thanks
    17
    Rides
    3
    Rep Power
    10
    if it is a single heater matrix ( not sure) i'd imagine there should be same temp both sides if blocked or not
    usually handy to get at just take out your glovebox, be easier check that first than flush the heater matrix
    i'm assuming you have dual control heaters for left and right side?
  12. The Following User Says Thank You to seanie For This Useful Post:
    scoobysub (13-03-2018)
  13. #12
    Member Number 2766
    ISDC Club Treasurer
    scoobysub's Avatar
    Join Date
    Nov 2008
    Location
    kilkenny
    Posts
    12,063
    Thanks
    2,810
    Rides
    1
    Rep Power
    10
    Chances of the heater being blocked are slim I’d be checking the actuator first
  14. #13
    Member Number 16 davelegacy's Avatar
    Join Date
    Jul 2006
    Location
    Dublin
    Posts
    13,755
    Thanks
    343
    Rides
    0
    Rep Power
    31
    Im 99% each side is elec motor controlled.
    So a motor may be failed
  15. #14
    Join Date
    Jan 2017
    Posts
    16
    Thanks
    0
    Rides
    0
    Rep Power
    0
    Thanks folks .
    Guess I will te think so and double check acctuator / motor first .
    Going to be a week or so before I get shed time etc .
    Seanie
    Thanks for photo that helps .
    Does anyone do s manual for these . Something like the Haynes type manual ?
  16. #15
    Join Date
    Aug 2017
    Posts
    390
    Thanks
    320
    Rides
    0
    Rep Power
    5
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
