Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
Thread: Legacy slugish start
  1. #21
    Committe Members Ciaran WRX's Avatar
    Jan 2013
    Ireland
    11,806
    4,585
    1
    55
    Fyi Varta built in same factory identical
  2. #22
    Commitee Member / ISDC Event Organizer GORDON GT SERIES II's Avatar
    Mar 2008
    offaly
    7,048
    1,624
    1
    32
    City auto are actually closed now Ciaran closed the door about a month back
    Sent from my SM-G930F using Tapatalk
  3. #23
    Jan 2013
    Ireland
    11,806
    4,585
    1
    55
    Quote Originally Posted by GORDON GT SERIES II View Post
    Jeazus that's mad
  4. #24
    Mar 2008
    offaly
    7,048
    1,624
    1
    32
    Yeah man one of the oldest factors in Dublin heard a lot of stories lads pretty much giving stuff away shame really
  5. #25
    Jan 2013
    Ireland
    11,806
    4,585
    1
    55
    There a long time alright always a shame to see
  6. #26
    Full ISDC Club Member Jarocki's Avatar
    Jul 2016
    Dublin
    303
    8
    3
    That is a shame alright. I actually found the battery on eurocarparts, link below for €158.90. Is that a good price? Seems expensive for a battery though never had to bu one for a car before.
    https://www.eurocarparts.com/en_ie/e...057&1&cc5_1002
  7. #27
    Sep 2015
    wexford
    289
    212
    5
    The exact same thing is happening to mine since I've had it off the road.
    Gonna get new battery and hopefully sorts it out.
  8. #28
    Jul 2016
    Dublin
    303
    8
    3
    Just found this crowd. Rang them there to see if they can order in for this price. Some difference.
    https://dexterautoparts.ie/batteries,36219,0.html
  9. #29
    Jul 2016
    Dublin
    303
    8
    3
    I picked up the bosch battery from dexter auto for €95. I installed it last night. Brought it for a small run. This morning However similar symptoms to before. The drive to work was 45 minutes. Will see how it starts after work at 4pm. If it's the same i may bring the car down to Ciaran Larkin to check it out.
  10. #30
    Jul 2016
    Dublin
    303
    8
    3
    So after changing the battery out the same symptoms are there after a day without driving. Just a slight struggle to start.
  11. #31
    Full ISDC Club Member Gary sti's Avatar
    Jan 2017
    Dublin
    1,842
    1,197
    13
    Quote Originally Posted by Jarocki View Post
    The fact that you have a new battery in if you have a volt meter battery should be 12v-12.4v with engine turned off. Turn on car with engine running a healthy alternator should read about 14v for recharging might be not be working 100% could be strain on battery. Or starter just showing a bit of age had this on other car local garage struggling to find what it was I bit the bullet put new starter in bang on perfect. But a decent garage should be able to spot it I think
    My Impreza would take a couple of turns to get going sometimes but not driven Daly if this helps
  12. #32
    Jul 2016
    Dublin
    303
    8
    3
    Yes thanks for that advise. Can is an 06 so possibly the starter. Will get the car down to Ciaran Larkin over the next few days when he is available.
  13. The Following User Says Thank You to Jarocki For This Useful Post:
    Gary sti (14-03-2018)
  14. #33
    Jul 2016
    Dublin
    303
    8
    3
    Had the car down with Ciaran and before he spends time on it. He said he is confident it will start every time and before he spends days trying to diagnose it without spending money on parts we agreed to leave it for the time being see how it goes. He did all tests and alternator reading 14V and when started battery drops to around 8 volts on start up. So possibly is the starter. Just not 100%.
  15. #34
    Jan 2008
    323
    11
    happened to me before, had a bad connection to the crank sensor
  16. #35
    Jul 2016
    Dublin
    303
    8
    3
    That's interesting. Do you have a legacy too? How did you spot the bad connection?
  17. #36
    Jan 2008
    323
    11
    yea have a 05 legacy , mechanic friend diagnosed it , the starter in the legacy sounds very lazy as well ,very slow to turn. mine used to turn and turn for ages and eventually fire up.
  18. #37
    Jul 2016
    Dublin
    303
    8
    3
    Yep the legacy was always a little slow to start alright. Ciaran did say the starter was drawing a little higher current than normal which would explain the lower voltage at the battery on startup.
