Page 1 of 2 12 LastLast
Results 1 to 20 of 37
Thread: Legacy slugish start
  1. #1
    Full ISDC Club Member Jarocki's Avatar
    Join Date
    Jul 2016
    Location
    Dublin
    Posts
    345
    Thanks
    18
    Rides
    0
    Rep Power
    4
    Hey. Hope someone might have an idea. The last couple of weeks my legacy BP5 turns over but as the engine starts the revs drops to almost cut out and then runs no problem. Once started the car runs perfect and has no issues at all. This only happens if car is not started for a day or so. If i start the car after a drive it starts no problem. Last week after work it took 3 turns of the key and a push of the accelerator to get it going. It was turning over just not starting. It is an auto box. Thanks in advance.
  2. #2
    Member Number 2766
    ISDC Club Treasurer
    scoobysub's Avatar
    Join Date
    Nov 2008
    Location
    kilkenny
    Posts
    11,930
    Thanks
    2,674
    Rides
    1
    Rep Power
    10
    Battery would be the first check as it could be on the way out , if no that then weak starter but try the battery first
    colin, richard, bertie, frank, gone but not forgotten.
    Peter marks account Reopened in Style!!!
  3. #3
    Join Date
    Jul 2016
    Location
    Dublin
    Posts
    345
    Thanks
    18
    Rides
    0
    Rep Power
    4
    Thanks Joe i will check that out.
  4. #4
    Sunday Drivers Lynx's Avatar
    Join Date
    Nov 2016
    Location
    Dun Laoghaire
    Posts
    158
    Thanks
    13
    Rides
    0
    Rep Power
    2
    Try turning the key to ACC for a few moments, waiting till the fuel pump creates the pressure, then start.
    If this helps, might be fuel return valve fault.
  5. #5
    Join Date
    Jul 2016
    Location
    Dublin
    Posts
    345
    Thanks
    18
    Rides
    0
    Rep Power
    4
    Thanks yes i did try that alright and has no affect to the cars starting.
  6. #6
    Join Date
    Nov 2016
    Location
    Dun Laoghaire
    Posts
    158
    Thanks
    13
    Rides
    0
    Rep Power
    2
    Quote Originally Posted by Jarocki View Post
    Coolant temperature sensor is another option.
    My subarus usually did start even when the starter could hardly rev the crank at -30 and 9 volts at the battery.
    The rev dive after starts says that the mixture is poor, which might be the fault of the coolant temperature sensor. When it is dead, the ECU is probably taking the default temp (must be around +20) into account, and until lambda corrects it, you see low revs.
  7. #7
    Committe Members Ciaran WRX's Avatar
    Join Date
    Jan 2013
    Location
    Ireland
    Posts
    12,076
    Thanks
    4,758
    Rides
    1
    Rep Power
    60
    As joe said money on battery
    Low recent temps play havoc with batterys
    Make sure if getting on u get one with high Cold cranking amps (CCA)
  8. #8
    Join Date
    Nov 2016
    Location
    Dun Laoghaire
    Posts
    158
    Thanks
    13
    Rides
    0
    Rep Power
    2
    -30 is cold. +3 is not.
    Cold effect the battery, when part of the electrolyte has turned into water. Water turning into ice lowers the battery capacity. Haven’t heard of water turning into ice above zero.
    It is possibly the dead battery, but cold has nothing to do with it.
  9. #9
    Join Date
    Jul 2016
    Location
    Dublin
    Posts
    345
    Thanks
    18
    Rides
    0
    Rep Power
    4
    Will get a meter on the terminals and see what the readings pre start up and when on.
  10. #10
    Join Date
    Jul 2016
    Location
    Dublin
    Posts
    345
    Thanks
    18
    Rides
    0
    Rep Power
    4
    If it is a battery issue does anyone have any recommendations? I am not sure what is in the car will check later on.
  11. #11
    Join Date
    Jan 2013
    Location
    Ireland
    Posts
    12,076
    Thanks
    4,758
    Rides
    1
    Rep Power
    60
    Stick to quality brands bosch/varta
  12. #12
    Join Date
    Jan 2013
    Location
    Ireland
    Posts
    12,076
    Thanks
    4,758
    Rides
    1
    Rep Power
    60
  13. The Following User Says Thank You to Ciaran WRX For This Useful Post:
    Jarocki (27-02-2018)
  14. #13
    Join Date
    Nov 2016
    Location
    Dun Laoghaire
    Posts
    158
    Thanks
    13
    Rides
    0
    Rep Power
    2
    If the battery is less than 5-6 years old, it might be worth trying to charge it.
    I have a charger, and a multimeter to check whether it’s helping or not...
    And a BT OBDII, if a scan is needed.
  15. #14
    Join Date
    Jul 2016
    Location
    Dublin
    Posts
    345
    Thanks
    18
    Rides
    0
    Rep Power
    4
    I was down in consort yesterday and they threw a battery tester on it. What came up was a recharge was recommended. Now when i drive to work would be going for 45 minutes each way. Surely that would give it the recharge it needed??
  16. #15
    Join Date
    Nov 2016
    Location
    Dun Laoghaire
    Posts
    158
    Thanks
    13
    Rides
    0
    Rep Power
    2
    Basically no. And if driving to work includes a lot of idling in traffic, just the opposite.
  17. #16
    Join Date
    Jul 2016
    Location
    Dublin
    Posts
    345
    Thanks
    18
    Rides
    0
    Rep Power
    4
    Generally no idiling. Mostly motorway roads to be honest.
  18. #17
    Join Date
    Nov 2016
    Location
    Dun Laoghaire
    Posts
    158
    Thanks
    13
    Rides
    0
    Rep Power
    2
    On high revs the alternator will output more; the problem is that the dead battery needs low current to be restored.
    The rule for a relatively new battery is 1/10 of the capacity for 10 hours.
    But let’s say 1/20 for 20 hours would be better for a deeply discharged battery.
    Just driving will keep it on the edge, won’t charge it fully.
  19. #18
    Join Date
    Jul 2016
    Location
    Dublin
    Posts
    345
    Thanks
    18
    Rides
    0
    Rep Power
    4
    Hey looking to pick up that bosch s4 024 but couldn't find a supplier online in ireland. Anyone any recommendations where to buy online?
  20. #19
    Join Date
    Jan 2013
    Location
    Ireland
    Posts
    12,076
    Thanks
    4,758
    Rides
    1
    Rep Power
    60
    Got mine here
    Dealers for Bosch
    Give em a shout
    http://www.cityautos.ie
  21. #20
    Join Date
    Jul 2016
    Location
    Dublin
    Posts
    345
    Thanks
    18
    Rides
    0
    Rep Power
    4
    Thanks will give them a shout tomorrow to get a price.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
