Bought my first subaru a few months back so have been doing a lot of reading and learning about them.
Looking to find out if certain intake mods are worth it or not as I cannot find solid enough info/opinions
about the results.
Car is a jap import 2002 bug wagon sti.
First one is turbo inlet pipe. Are the aftermarket ones(Samco, Perrin, decent brands etc.) capable of unlocking some ponies over the standard plastic one? I have no issue with current pipe but would be happy to reduce any restriction into turbo compressor as it does look a pretty small diameter. Turbo is Vf30.
Second is inlet manifold riser/tgv body. I am aware I do not have tgv fitted to my car but from what I can gather there is room for improvement by cutting out a shelf that is is sat inside each of the bodies. Bit of cutting, grinding and smoothing would remove this, but am I write in saying there is a restriction there in the first place or is my info wrong?
I understand the "gains" here are minimal but as I would probably remove the manifold to do either, I might aswell do both. Unless I'm completely off the mark?
If I went ahead with this, I've also read there was a bit of an issue with a fuel pipe leaking during cold wether, fixed by fitting a slightly longer bit of rubber pipe. Might aswell do this while in there also.
I plan on 3" exhaust turbo back, panel filter, fuel pump, 3 port boost solenoid and remap with octane booster at the end so all mods will be made the most off.
What does yous think or have experience with?
Cheers!
about the results.
Cheers!
