Fozzy
Ok, so I opened up the rear diff on the ratmobile and found that it’s not a 4.44 despite the whole interweb telling me it would be - it’s actually a 4.11 (37:9 on the crownwheel) I need a 4.44 - my own crownwheel is good it’s the pinion that’s failing so, does anyone know is I can just swap the crown wheels and, if so, is it relatively easy to do or ballache? As the housing is identical and as the 4.44 is a 39:9, I’m assuming the crown wheels will be the same diameters and the pinions will be the same also, will I require new seals, o-rings, gaskets etc?
Thanks in advance
Thanks in advance
