Results 1 to 16 of 16
Thread: Brembo bleed nipple sheared off
  1. #1
    Full ISDC Club Member BazGF8's Avatar
    Join Date
    Feb 2008
    Location
    Dublin
    Posts
    6,267
    Thanks
    387
    Rides
    0
    Rep Power
    20
    Has this happened anyone and what are the options to get it removed without damaging threads?
    V4 Sti Wagon
  2. #2
    Full ISDC Club Member Keadeen's Avatar
    Join Date
    Apr 2013
    Location
    Wicklow
    Posts
    1,935
    Thanks
    324
    Rides
    2
    Rep Power
    13
    Hi Baz, hope you're keeping well mate.
    Search for stud extractor kits like LINK. Only way to do it if sheared off and little or no protruding part of the nipple left sticking out over the caliper body. Will need to take caliper off, drill a pilot hole (has to be done on a column drill to make sure dead straight and dead centre of nipple (if off then will either damage caliper thread, and/or the remaining nipple material too little and will be "pushed out" by the tapered extractor tool and "jam/seize" nipple even tighter in the caliper) and then "tap" in the left turning extractor tool. At best a 50/50 shot though if badly seized to start with. In the past have found it can help to heat the caliper in the oven for a good even heat that won't damage caliper (after drilling hole but before fitting extractor) and then blasting remaining stud/bolt/nipple with "thermal shock" spray can like for example Halford's Shock & Unlock.
    Hope it works out fella.
    96 STI v3
    04 WRX SL
    07 Hawkeye STI UK Type
  3. The Following User Says Thank You to Keadeen For This Useful Post:
    BazGF8 (04-02-2018)
  4. #3
    Join Date
    Feb 2008
    Location
    Dublin
    Posts
    6,267
    Thanks
    387
    Rides
    0
    Rep Power
    20
    Cheers Charles
    V4 Sti Wagon
  5. #4
    Member Number 2766
    ISDC Club Treasurer
    scoobysub's Avatar
    Join Date
    Nov 2008
    Location
    kilkenny
    Posts
    12,002
    Thanks
    2,744
    Rides
    1
    Rep Power
    10
    Talk to Nigel bracken happened him . He got stainless steel replacement ones that are very cool have a nipple in a nipple so it can never happen again
    colin, richard, bertie, frank, gone but not forgotten.
    Peter marks account Reopened in Style!!!
  6. #5
    Commitee Member / ISDC Event Organizer GORDON GT SERIES II's Avatar
    Join Date
    Mar 2008
    Location
    offaly
    Posts
    7,243
    Thanks
    1,702
    Rides
    1
    Rep Power
    34
  7. #6
    Full ISDC Club Member Gary sti's Avatar
    Join Date
    Jan 2017
    Location
    Dublin
    Posts
    2,195
    Thanks
    1,641
    Rides
    0
    Rep Power
    16
    Quote Originally Posted by GORDON GT SERIES II View Post
    There the right job
  8. #7
    Join Date
    Aug 2014
    Location
    Rathangan co Kildare.
    Posts
    303
    Thanks
    196
    Rides
    0
    Rep Power
    7
    There the ones I used when it happened to me. Had to be drilled and tapped they work well.
  9. #8
    Join Date
    Aug 2014
    Location
    Posts
    303
    Thanks
    196
    Rides
    0
    Rep Power
    7
    That is it on the caliper. Probably could do with a bit of paint.
  10. #9
    Join Date
    Feb 2008
    Location
    Dublin
    Posts
    6,267
    Thanks
    387
    Rides
    0
    Rep Power
    20
    Quote Originally Posted by nigelbracken View Post
    How did you get the old one out?
    The dust seals on mine are melted from track use so I’ll have them off soon
    V4 Sti Wagon
  11. #10
    Join Date
    Mar 2008
    Location
    offaly
    Posts
    7,243
    Thanks
    1,702
    Rides
    1
    Rep Power
    34
    Quote Originally Posted by BazGF8 View Post
    Might be overkill but could be an answer as well I've been looking at them
    https://rover.ebay.com/rover/0/0/0?m...2F253374283824
  12. The Following User Says Thank You to GORDON GT SERIES II For This Useful Post:
    BazGF8 (04-02-2018)
  13. #11
    Join Date
    Aug 2014
    Location
    Posts
    303
    Thanks
    196
    Rides
    0
    Rep Power
    7
    I drilled and retapped it. Was a pain in the hole
  14. #12
    Full ISDC Club Member seanie's Avatar
    Join Date
    Jul 2012
    Location
    Clare
    Posts
    1,254
    Thanks
    17
    Rides
    3
    Rep Power
    10
    Have full set of front and back seals there somewhere baz if you need them
    V5 STI TYPE R V-LIMITED
    BOB RAWLE MAPPED 346BHP/328FTLB
  15. The Following User Says Thank You to seanie For This Useful Post:
    BazGF8 (04-02-2018)
  16. #13
    Join Date
    Feb 2008
    Location
    Dublin
    Posts
    6,267
    Thanks
    387
    Rides
    0
    Rep Power
    20
    Cool
    V4 Sti Wagon
  17. #14
    Join Date
    Feb 2008
    Location
    Dublin
    Posts
    6,267
    Thanks
    387
    Rides
    0
    Rep Power
    20
    Quote Originally Posted by seanie View Post
    Ah balls only ordered a set
    V4 Sti Wagon
  18. #15
    Join Date
    Jul 2016
    Posts
    59
    Thanks
    33
    Rides
    0
    Rep Power
    3
    Hi Baz,
    With a bit of care its possible to save the threads on your caliper. The bleed nipple locks out on the tapered seat at the base of the threaded hole. Once you remove this pressure, the remains of the nipple should unscrew quite easily.
    Measure the diameter of an undamaged nipple just in front of the thread.(It's around 7.0 mm) You need to drill down the centre of the sheared nipple to a depth which just clears the depth of the thread. Do it in steps, 0.5 mm larger drill diameter at a time. This will ensure the drill bit follows the centre line of the bore in the nipple.
    Not easy to do with a hand drill. Better to remove the caliper and use a pillar drill or mill & angle plate - you do not want to drill too deep! The tapered seat on the caliper must remain untouched. Once done the square tang of a file works great - using a hammer tap it into the remains of the nipple and unscrew.
    Next fish out the remains of the tapered tip of the old nipple, Clean everything before fitting a replacement.
  19. The Following User Says Thank You to Alan Browne For This Useful Post:
    BazGF8 (05-02-2018)
  20. #16
    Join Date
    Feb 2008
    Location
    Dublin
    Posts
    6,267
    Thanks
    387
    Rides
    0
    Rep Power
    20
    Quote Originally Posted by Alan Browne View Post
    Hi Baz,
    Thanks Alan, great info there much appreciated
    V4 Sti Wagon
  21. The Following User Says Thank You to BazGF8 For This Useful Post:
    Alan Browne (07-02-2018)
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
