Broken Drivers Window Switch
ShortyNI
Hi everyone,
I have broken drivers window switch on my 2005 Impreza WRX, when it was in the down position and am desperate for a quick fix before the snow comes tonight. I have a semi waterproof cover on the car but it is not keeping the damp out.
Is there a way i can wire one of the other switches to get the window up? does anyone know quick fix to do temporarily to do me until i find a switch. or does someone have a wiring diagram for it
Based in Northern Ireland so not many scrappies about to cater for me.
Enjoy the snow everyone and keep her out of the hedges.
Shorty
No good to help you get it fixed but is it a facelift dash 05. And here's 2 boys in the north breaking might have.
If you took off door card from what I remember when I fitted speakers in my own on the window regulator can you take off cable that is attached to motor and turn it manually to make it go up till you can get to root of problem that would be my thinking short term
Ps a few screws in behind door handle and latch to release card aswell as clips just take it easy not to force
Thanks the info. Took the window module apart and the switch seems to be working mechanically. I'm assuming the motor has packed in so the disassembly info and boys breaking is a great help. Car interior is now soaking wet. Nightmare
