miltek decat downpipe for twinscroll.
ben1973
As above.
I'm not 100% sure which engines this fits but I know it doesn't fit a 06 legacy..
Matches up to turbo,but fouls on gearbox.(auto)it could be off a manual.
The part no. Is in pics so do a bit of checking first.
I cut flange off to see if it would fit - it didn't.
I can weld flange back on if needed.
150 euros.
it will fit the manual on the turbo flange but will need to be modified to fit the rest of the exhaust system as its only really designed to be fitted with the rest of the milltek system for the twinscroll
Nice upgrade for someone all the same, Needs a remap once fitted as it will be boost spiking like crazy with that large pipe fitted
Seems like its missing the gearbox mount too to secure it onto the gearbox?
Yes.thats the way it came to me.i have a small section of the midpipe that has a mount on it,so that could be mdified to make a bracket, or the mounting point on the original downpie can be removed and welded onto this.(that's what I was going to do)
Thanks Dan:thumbsup:
Yep, probably...
I had already cut off the original exhaust side flange as is was very thin and I didn't like the look of it.i had welded on a thicker flange and after two hours of trying to remove the foookin heatsheild, I was gonna try anything!!!
Man ,that heatsheild is a complete nightmare to remove. But it's all learning.
I had car booked in to be mapped and was speaking to the tuner afterwards,I told him what had happened and he said that it wouldn't need to be remapped again if I put the downpipe on....
