Lupo 2002 Cel question
Ciaran WRX
Alright lads Friend has a Lupo that's been showing a cel for last few months
And recently passed a nct with it on[emoji2] but is now selling it and needs it off
Things replaced so far to try solve
Spark plugs
Leads
Coil pack
Lambda o2 sensor bank 1
When pluged in showing "misfire cyl 1"
Runing perfect just cel issue
Any ideas as needs it gone ..
And he's head is wrecked..
Thanks lads
Either a dodgy No1 lead Ciaran or needs plugs.
Normally on those when the engine is at running temp the leads/s break down.
Could also be a ****y injector but would be very rare!
Is it lumpy? Misfiring?
Thanks Graham
1.0
I'll get him to double check leads
Running perfect idling smooth ect
Pluged in my odb getting thease faults clear them and 10 secs later cel back on
Looks like lambda 1,I'd say a lead/plugs and possible throttle body issue.
I'd do a Compression test first though to rule that out.
Sound Thanks
plugs new (do plugs have to be Bosche in vag?) Leads all apear fine
Was thinking fuel filter mabay?
Lambda prob next thing to do is say as above [emoji106]
Plugs should be fine once they are correct for that engine.
Be no harm changing the fuel filter, nobody changes them here unless it’s diesel.
I’d say the lambda is the issue, common on Vw.
Cheers man
I'll let u know what happens [emoji106]
