Results 1 to 7 of 7
Thread: Question for the boost Guru's
  1. #1
    Full ISDC Club Member
    Aug 2017
    43
    46
    Hi folks,
    The forester is running a vf28 with TMIC and walbro fuel pump. Drives really well and pulls hard with a decent kick from the turbo.
    The limiter was set to 0.8bar when I got it, feels like there's plenty more there so I assume it's been dialled in conservatively. I'm not sure what injectors are in there and would ideally like to have a mapper look at what's going on before I play with the levels but would I be right in thinking that I should be able to push it up to 1.2ish safely ?
  2. #2
    Committe Members Ciaran WRX's Avatar
    Jan 2013
    Ireland
    10,764
    3,799
    1
    43
    Get her booked in with Ahongus in Galway did mine few years ago very happy with it
    He will get most from it while remaining safe and drivable
    0.8 standard boost of euro wrx mine at 1.3 so should be no problem as basically same engine
  3. The Following 2 Users Say Thank You to Ciaran WRX For This Useful Post:
    Fozzy (12-09-2017), SCOOBYCOLM (12-09-2017)
  4. #3
    Aug 2017
    43
    46
    Quote Originally Posted by Ciaran WRX View Post
    Cheers Ciaran,
    A mate of mine has the software so we're going to plug in the laptop and take a drive on Thursday - have a look at the map and see what's going on with the AFR, boost etc. We don't have enough experience with them (yet) to be confident making any major changes but it should give me an idea of the limits I'm looking at
  5. #4
    Aug 2017
    43
    46
    So, interesting evening.
    Couldn't get into the ECU but had a good root around. Despite the turbo and fuel pump upgraded, she's still only running stick boost. Speaking to Aonghus Power, the set up should be good for 1.4-1.5 happily. Can't understand why someone would go to the trouble of doing all that work and not remapping it.
    Best guess is that it had an aftermarket ecu at some point which was pulled out and replaced with stock. Good news is that it will be a beast at twice the boost but now I need to work out if the stock JDM ecu is mappable - if so, happy days - very cheap smile value, if not, then I'll have to sort an ecu.
    Stone motorsport have just got a four wheel dyno and are not too far away. Any feedback on Joe Power? Also there's westward engineering and Aonghus Power but the latter is a long drive away
  6. #5
    Full ISDC Club Member Pedro555's Avatar
    Nov 2013
    clare
    2,225
    1,522
    15
    Go with aonghus power, it's only two hour drive from Dublin to his place in Galway and really worth it, he is a perfectionist,
    Subaru Impreza WRX STI Type R -Version 4 V Limited
  7. The Following 4 Users Say Thank You to Pedro555 For This Useful Post:
    BazGF8 (15-09-2017), Ciaran WRX (14-09-2017), Fozzy (15-09-2017), Tad (15-09-2017)
  8. #6
    Member Number 3801
    Aug 2010
    Meath
    3,119
    231
    14
    Stones dyno is the same as Aonghus. Joe is involved with brit car/land speed records/Le Man's 24 hour etc. Aonghus has been doing UK sessions and rally cars etc lately aswell.
    It's all much of a muchness. Both well capable, just depends who can squeeze you in sooner. If you get through. :D
  9. The Following User Says Thank You to JohnRA For This Useful Post:
    Fozzy (16-09-2017)
  10. #7
    Aug 2017
    43
    46
    Quote Originally Posted by JohnRA View Post
    I got talking to Joe, he said mapping the stock JDM ecu should be no problem that he's done a good few of them before, auto might make it a bit slippy on the dyno but should be no problem. He's going to try and fit me in before Japfest which would be great! I'm in Kilkenny so Galway is over 3hrs away - stone is handier to get to.
    I think it will be an absolute monster if I get up to 1.2bar or above - it's not much slower than the FD as it stands - it's the daily driver so want to keep it pretty safe, especially when it comes to the box and slap on the downshift - I'll keep you posted!
