A bit of vw help
Gary sti
https://vimeo.com/219431536
This is Drive shaft on 2008 transporter 130bhp it is only in a couple of months so it's not worn neither is passo side took it out and had a look this is doing my head in every day I wonder is the diff starting to ware in gearbox I was planning on changing van soon but ain't going to sell some one else my problem I wouldn't like it done to me. Any advice would be great. I have no other noise in van apart from this clunk every time I take foot off accelerator put it back on it's there.
If splines on shaft and box are ok then it is backlash betwen planet and sun gears or between diff ring gear and pinion, some backlash is normal but excessive means box overhaul to fix
Would u say this is excessive amount of play as I said no noise whines crunching of gears but van drives good no prob expect for this
There is a small splined shaft between gearbox and drive shaft.could be this
.changed one lately and had similar issue to this.
As above, replace shaft and spline part coming out of box.
Piece of piss to do.
Graham that is a brand new one in it shaft and spline that's why I am wondering where exactly the clunk is coming from would it be out of gears van drives perfect apart from this use it for work every day don't want to be left on side of rd again. Would there be ever any play in diff?? Might be going on a bit but wasn't like it before other shaft snapped 1800000 on clock
had same thing on an 09 transporter I had .
done another 60 k with me and never proved an issue and another guy had it for another year or more and never failed but clunk would get on your wick
Has to be internal in the box so If they are new genuine parts.
New Vw vans are great but when warranty runs out time for another new one.
No just motor factors what kind of interns, reconditioned and what kind of money [emoji383]????????
No just motor factors what kind of interns, reconditioned and what kind of money [emoji383]����
No idea, we send all that gearbox stuff out for repair to a specialist.
We don't have time for it at our labour rates.
Price is normally around 600 to recon a box if you hand it to them.
Thanks for advice graham it's a strange one maybe just other two cars don't do it so more one my mind when jump into van. Have to be honest only thing it's got is maintained every 12000km starting motor discs and drive shaft,bushes I know of lads who have had big trouble alright but if you do look after anything trouble is never two far away. Parts are dear alright guy who knows me from buying bits is nearly apologetic before he give price think going to be changed for a ford custom better spec,5 year warranty and a couple of grand cheaper always had vw vans but there just a bit out of reach and not much changed with them we shall see
Right took out shaft little or no play in gear box but when put gearbox stub in end of shaft there is a little bit of play but not a good fit and can wobble here is a vid any thoughts this is not a genuine driveshaft only spurioushttps://vimeo.com/225001586
That's the new shaft and stub only 3 months old at this stage I would buy vw one if it fixed it van jacked up in driveway sheared bolt nearly have it out starting to rain can't win any advice welcome thanks Tad I am thinking it's not great there is f*^k all play in gears has to be shaft
If I thought the genuine was better I'd buy it I done a lot of machine fitting for years there is no way would that wobble be in any drive units on to motors just want to be sure before I pay top whack
Plus selling van can't sell it with problem
Just private sale was cheaper to buy new one without trade in saved nearly 3k if trading in I would loose that
