EJ20T Short-Block Identification
JJEJ20
Can anybody tell from the pictures what year/model this block is from?
Not sure now but I dont think it's possible I tried myself once to identify block even carrol and roche couldnt help me.
This might help a bit
Generally the EJ-series can be divided into two versions: the Phase I engines (1989–1998) and the Phase II engines (1999–2010). The Phase II engines featured new cylinder heads and crankshafts with the thrust bearing located at crank bearing #5 instead of #3. The designation also changed from Phase I to Phase II. All Phase I engines have an alphanumerical suffix behind the standard EJXX designation, all Phase II engines have a numerical suffix behind the EJXX designation. Example:
Phase I: EJ15E, EJ15J, EJ16E, EJ18E, EJ20D, EJ20E, EJ20G, EJ20H, EJ20J, EJ20R, EJ20K, EJ22E, EJ221, EJ25D
Phase II: EJ151, EJ161, EJ181, EJ201, EJ202, EJ203, EJ204, EJ205, EJ206, EJ207, EJ208, EJ222, EJ251, EJ252, EJ253, EJ254, EJ255, EJ257
ud have to split block to find out which thrust bearing
