Grimmspeed oil air
keith dublin
Any one here using a grimmspeed oil air separator or has any input or information on them are they good or bad
Cheers.
Keith.
I used one before , better options out there to manage blow by in my opinion Keith
What did you use baz
Just seen this one is handy as to sits in the position on the oe oil cap.
Rcm return to sump catch can with a mocol banjo bolt fitting that fits into the bottom of the sump .
They re handy but they do **** all in my opinion.
What problem you having ?
Not having any problems I was just reading about them on line saying they reduce oil in the intake and can reduce det as the octain ....but I think your right about doing **** all not worth the hassle
I wouldn't bother for a road car...
If you really want to, I would only use a non return set up on a road car
