Subaru Legacy Twinscroll
Jasper
So I've decided to put me Legacy up for sale and see if there's any interest. The reason I'm selling is that is was always intended to be a stop gap to something newer and TBH, its such an effort to drive it!! There's alot of speed bumps on the way to work and rough roads, I may as well be in first gear going over the speed bumps so as not to damage the front lip! Plus my commute is only 15 min and it takes longer to warm up the car than drive it to work :) (Slight exaggeration but you get the point)
In saying all that, I do love the car and when I'm not driving sh*t roads to work, I love driving it!
I'm not desperate to sell and will continue to "baby" the car, a lot has gone into it since my ownership, I understand you don't get back what you put into modified cars but it would be nice......
I'm asking for 10.5k.
I bought the car of Dan last year, here is the thread-
http://www.isdc.ie/forum/showthread...cy-twinscroll-for-sale-(&highlight=twinscroll
In my ownership I have done the following-
Fit BREMBO STi calipers
New Project MU NS400 Front Pads
New Front Dimple Groove Discs
Rear Caliper overhaul incl pistons and seal kit
New Rear Pagid Pads
Oil and Filter change
New Genuine Subaru Lambda Sensor
Rear Diff Oil Change
Car Remapped by Duncan/Race Dynamix
Before Xmas the car developed a stutter when driving down the N4. Turned out to be 2 bent exhaust valves! I had this sorted by the lads at RSR Automotive and the following work carried out-
ACL Race Big End Bearings
ACL Race Main Bearings Rear Thrust
Coolant
Fuchs Oil 10/40 5L (Run In)
NGK Iridium 7's Spark Plug Set (4)
RCM "Stopper" Head Gasket 1.5mm
RSR Timing Belt Kit with Water Pump
Subaru Genuine Bottom End Seal Kit
Subaru Genuine Cam Seal V7+ AVCS
Subaru Genuine Crossover Pipe Seal
Subaru Genuine Exhaust Gasket GDB Twin Scroll Turbo-Downpipe
Subaru Genuine Exhaust Gasket GDB Twin Scroll Turbo-Uppipe
Subaru Genuine Exhaust Gasket Head-Header
Subaru Genuine Inlet Manifold Gasket.
Subaru Genuine Oil Filter
Subaru Genuine Oil Pump and Seal
Subaru Genuine Rocker Cover Gasket Inner
Subaru Genuine Rocker Cover Gasket Outer
Subaru Genuine Sump Bung Washer
Subaru Genuine Thermostat and Seal
Subaru Valve Stem Oil Seal Exhaust
Subaru Valve Stem Oil Seal Inlet
Engineering Shop. Head Strip. Deck Surface. Recut Valve
Seats.Re-Assemble, Shim Clearences check/adjust.
Engineering Shop: Deck Block Half.
Rehone Cylinder.
2x New Exhaust Valves
Oil Service carried out yesterday 13/Apr/17
Re Test Drives- All Test Drives will be done by me and car will not be given full boost. Map needs to be looked over to ensure everything is running spot on. Will be done in the coming weeks (Yes I know, pain in the hole)
NCT booked for 23rd this Month.
Update............ NCT passed on 23rd April
I think that's everything !
Text/Call/Email
Shane
0879340697
shanekennedy1@yahoo.ie
Few pics now- Most copyrighted by Dan :)
Pics
pics
Lovely car, has all the right bits done and real head turner. Best of luck with the sale.
Beautiful legacy, possibly nicest one in the country. Have always admired it.
Just one thing, how is a potential buyer going to know its the car for them if they are not allowed drive it.
I am all about not letting people just go for a spin in your car when trying to sell. But for genuine buyers a car can feel very different from the drivers seat compared to the passenger seat
I'd agree with Chris. Maybe the sale is a bit premature if you're not comfortable with someone test driving it. Hang off for a bit longer if it's the running in and map tweak that you don't want someone test driving it. Put some miles on it and book it in with Duncan next time he's over.
If you managed to find someone to buy it on looks and passenger spin alone, you could see it pop back up for sale quickly within their ownership.
Great car I feel your pain about the map
I was going to sell my car a few months ago and wasn't sure to map it beforehand or just sell as is so I thought if I was buying a car I'd want to give it full lash before I handed over ant cash so I decided to get it mapped.
Completely agree with the comments lads, I'd want to drive a car if I was buying it :)
It is early days yet and just wanted to generate some interest.
I probably should edit the add to say, after mapping to ensure everything is 100%, then serious buyers can drive it :)
NCT booked for Sunday and map to be looked at in coming weeks so will update then.
That was me beeping at you today on the N4in the grey a7 :), Shes looking well! If only i had room for a second car :)
But you didn't see me Dan flashing you in a big yellow and blue thing on island bridge Dan lol
Car looking well
Place is full of bus wankers
I suppose that's what happens when you live beside a bus garage
