Kyb Ultra Sr Rear Shocks
Ciaran WRX
Were fitted to Blob wrx non wide track.
Work perfectly no knocks ect
Same as below ones but used.
Dublin Collection
160
Hi are you 100% percent sure that these struts don't knock any idea how many miles they have covered also can you check the part numbers should be something like 321005 stamped on them cheers.
Working perfectly when removed don't know km very low mabay 10k max only taken out as got a deal on 4 ultras when doing full underbody refresh can't see the parts num on it but as bug and blob non wide track gotta recon it has to fit.
Where you located?
I'm in swords I just remember there being two part numbers when looking into it before but it was a while ago and the other part numbers around the same year may well have been relating to a wide track but if you had them in a blob wrx then surely they would go into a bug wrx as I'm new here I don't want to offend anyone but are you open to offers on these also were are you based cheers.
I'm in south Dublin can meet you somewhere with em not open to offers as bargin at that price and serious shock could benefit from a respray if your picky but should work fine as is
Cheers
