Ceramic coating or heat wrap ???
That is a choice we use @ RSR
Kaedens comment above can only be clarified with full removal of wrap for current corrosion level.
60k more is simply pie in sky heresay
Mileage also has a lot to do with timeframe/usage/storage.
There is no one answer to this.
RSR personally from experiance "saddle" the centre slip joints from new.
And also use the oversized bolt kit on the 3 bolt uppipe.
Not the Subaru sized bolts as supplied in the mainsteam.
This will lead to early failure on the 3 bolt gasket ( on a decent powered car) and that is not a nice job in place.
Wrap it and seal with the spray
Dei wrap doesn't last well, esp in Irish weather goes brittle with heat cycle and getting wet
if
if the budget allows ... coating is the only way to go ...
recently supplied a rcm manifold , bolt and gasket kit , zirotec coated for £970
zirotec coating on its own is £450
Typical rip off Ireland so they wanted 811.53 to ship to zircotec and then back to me absolute extortion cheers for the reply
