I have front wagon struts from my old blob and I think I have a set of sti springs..
What's the issue your having? I ran full spec c struts and springs in my bug wagon
Fairly sure shocks are same and all you need is wagon springs as rear spring rate is different.
Mine was a bit like that so I got lowering springs for just the front and it sorted perfectly whiteline sell front or rear sets so just order fronts and happy days here is how my bug sat
Here's a set very cheap
Look at this on eBay http://www.ebay.co.uk/itm/162125058999
If you do that it's the same issue you have now front slightly up! So the best way is just do the fronts but it is completely up to you man ????
But I taught your issue was the front too high? What offset are the wheels? I ran 225/40/18 with et48 offset and no rubbing at all and I carried very heavy loads in the back sometimes just rolled the rear arches
Et30 wheels are your problem wagon springs won't cure the issue only hide it a bit as the car will be higher
Wonder if you could just swop the rear top hats with your old shocks ?
