In my eyes the new impreza looks how the new a legacy should look. Not aggressive enough appearance wise to wear the impreza badge.
I have seen a few in person and they did nothing for me. Wouldn't look twice at one.
I would choose a spec c ra-r, s204, type r or p1 over an s207 any day. Saying that I'm looking forward to seeing how this performs.
Here it is in traditional blue Johnny
■Suspension / Mechanism |
・ Exclusive STI-tuned Bilstein front struts (DampMatic® II, inverted-type) and coil springs ・ Exclusive STI-tuned Bilstein rear dampers and coil springs ・ STI-designed BBS 19-inch × 8 1/2J forged aluminum wheels (silver) ・ Exclusive 255/35R19 92Y tires (Dunlop Sport Maxx RT) ・ STI-designed flexible tower bar, front ・ STI-designed flexible draw stiffener, front ・ STI-designed support front kit ・ STI-designed flexible support subframe, rear ・ STI-designed pillow ball bush rear suspension link (front and rear lateral links inside) ・ STI-designed Brembo front monoblock opposed-piston 6-pot brake calipers (silver coated with STI logo) with STI-designed Brembo 18-inch 2-piece drilled disk rotors ・ STI-designed Brembo rear monoblock opposed-piston 4-pot brake calipers (silver coated with STI logo) with STI-designed Brembo 18-inch drilled disk rotors ・ Exclusive high-output balanced engine ・ Exclusive engine control unit (ECU) ・ Exclusive twin scroll ball bearing turbocharger ・ Exclusive performance muffler with lowered back pressure (featuring STI logo) teamed with exclusive rear exhaust pipe ・ STI-designed strengthened silicon intake duct ・ Exclusive quick-ratio steering gearbox (11:1) ・ Exclusive Vehicle Dynamics Control (VDC) system ・ Exclusive Active Torque Vectoring system ・ STI-designed low-pressure-drop air cleaner element ・ STI Performance Oil (Motul 5W-40) |
■Controls / Instrument Panel / Warning Lights |
・ Exclusive luminescent instruments (with multi-information display and STI logo) ・ Exclusive multifunctional display ・ Central instrument panel visor (covered in silver-stitched leather-finish material) ・ Exclusive leather-wrapped steering wheel (highly tactile leather, chrome bezel, metallic finisher, silver stitching) ・ STI-designed push-type engine switch (red with STI logo) ・ STI-designed leather-wrapped shift knob (with STI logo) |
■Audio |
・ 8 speakers (4 front, 2 rear, 2 in instrument panel) ・ Black roof antenna (shark fin type) |
■Interior |
・ Exclusive STI-spec Recaro front bucket seats (leather [black semi-aniline finish on inside of main and side panels, silver stitching and accents] embossed with STI logo and equipped with seat heating and supplemental restraint system side airbags) ・ Rear seats : black leather with silver stitching and accents ・ Exclusive instrument panel (red with S207 logo) ・ Silver stitching on door trims ・ Exclusive side sill plates (silver with S207 logo) ・ Exclusive serial-number plate (console) |
■Exterior |
・ Exclusive mesh-type front grille (cherry-red stripe with S207 ornament) ・ Exclusive large front under-spoiler ・ Black side garnish with STI emblem ・ Exclusive metallic side sill moldings ・ Exclusive rear bumper (cherry-red stripe with air outlet grille) ・ S207 rear ornament |
■NBR Challenge Package: Exclusive Equipment |
・ Exclusive Ultrasuede-wrapped steering wheel (with silver center marking) ・ Exclusive red seatbelts ・ Exclusive emblem (rear) ・ STI-designed BBS 19-inch × 8 1/2J forged aluminum wheels (black) ・ Exclusive dry carbon rear spoiler (with S207 logo) |
■NBR Challenge Package Yellow Edition: Exclusive Equipment |
・ Black door mirrors ・ Exclusive yellow side sill plates with S207 logo ・ Exclusive black side sill moldings |
Dimensions/Weight | |
Model name/type | Subaru CBA-VAB |
Overall length/width/height (mm) | 4,635 × 1,795 × 1,470* |
Tire tread F/R (mm) | 1,535/1,550 |
Min. ground clearance (mm) | 135 |
Dry weight (kg) | 1,510 |
Gross weight (kg) | 1,785 |
Engine | |
Type/category | EJ20 horizontally-opposed 4-cylinder (Boxer) |
2.0-liter DOHC 16-valve dual AVCS twin-scroll turbo | |
Max. output (net) [kW (PS) / rpm] | 241 (328) / 7,200 |
Max. torque (net) [Nm (kgm) / rpm] | 431 (44.0) / 3,200–4,800 |
Fuel tank capacity (liter) | 60 |
Fuel type | Unleaded premium gasoline |
Model | Price (yen) | |||||
Model name | Grade | Engine | Drive | Transmission | Including consumption tax | Excluding consumption tax |
S207 | Standard-issue model | 2.0 liter Horizontally-Opposed 4-cylinder DOHC Turtbo engine | AWD | 6MT | 5,994,000 | 5,550,000 |
NBR Challenge Package | 6,318,000 | 5,850,000 | ||||
NBR Challenge Package Yellow Edition | 6,372,000 | 5,900,000 |
Since these vehicles have been customized, they must be presented at a Transport Bureau Branch for registration. |
That's nearly seventy K here and cleared. Beautiful car. Mad priceprice in Euro in Japan
Including consumption tax= 45,360.67 EUR
Excluding consumption tax = 42,001.60 EUR
