i want to install a kill switch to kill the power heading to the fuel pump, anybody know the best location to tap into a voltage feed wire heading to the pump? also what colour the wire is
The loom runs along the drivers side sill under carpet. Use a multi metre to check for continuity or check wire colour at fuel pump. U will be able to put a switch under driver seat or under dash somewhere around fuse box. Personally I would put another kill switch on a crank or cam sensor for extra security. Hope that helps u abit
