scoobycolm . ISDC Club Member Aug 14, 2015 #1 http://youtu.be/DoHpjbm7Ghc http://youtu.be/CLkc7xBnFSU http://youtu.be/16bidVopgUM http://youtu.be/ypmHT89M4M8 http://youtu.be/1To9l0UBQG4 from Rom Performance https://www.facebook.com/RomPerformance
keith dublin Member Number 161Full ISDC Members 2015 Aug 14, 2015 #2 Just watched all of them Colm great videos Are there any more on the rest of the build Cheers for that post
keith dublin Member Number 161Full ISDC Members 2015 Aug 14, 2015 #4 It would make us want to have a go What's the rest thrust bearing mod he mentions do they machine the block to take a new age bearing
davelegacy Member Number 16 Aug 14, 2015 #6 Yes machine cdb as centre thrust factory to accept a rear thrust bearing also. This allows your to then run a new age 2L or 2.5 L crankshaft. You can see this done here on one of our latest 2.1 stroker conversions with a cdb
keith dublin Member Number 161Full ISDC Members 2015 Aug 14, 2015 #7 Is it a much bigger bearing Dave
davelegacy Member Number 16 Aug 14, 2015 #8 You are just maching to accept rear thrust main bearing as are in all 99+ blocks.
keith dublin Member Number 161Full ISDC Members 2015 Aug 15, 2015 #9 Is there no bearing in the early block Any pic of both blocks Sorry for all the questions just trying to get me head around it
davelegacy Member Number 16 Aug 15, 2015 #10 Hi. Yes early ones were centre thrust. If look at pic from top to bottom. Can see bearing no.3 is the original thrust washer. Then bottom of pic. Bearing no.5 is also a thrust washer.
davelegacy Member Number 16 Aug 15, 2015 #11 Attachments uploadfromtaptalk1439627620947.jpg 1.1 MB · Views: 28 uploadfromtaptalk1439627644797.jpg 1.1 MB · Views: 28
