"I want 400whp!" Are you sure?
scoobycolm
From Nasioc :thumb:
I see these posts on a weekly basis. We all do. It always makes me feel really aprehensive (sp?) when I read it. So I just wanted to put this out there for those that are asking this question.
Are you relatively new to the Subaru thing? Have you ever owned a TRUELY high performance import before? Have you ever owned any HIGH powered car before? Do you have fairly deep pockets?
If you say no to any or all of the above, then I beg you, please read on.
Many many times people have come into the Newbie forum and made the statement "My goal is 400whp" and they almost always JUST got the car.
It needs to be said, and anyone wanting 400whpneeds to understand that 400whpis a LOT of power, and it takes a LOT to get there, and even more to do it reliably.
What will get you there?
Well, that depends on the dyno and tuner, along with how agressively you tune it. Dynos read differently and what makes 400whpon one dyny will make 450 on another, an 340 on yet others. Do you want 400whpon your local high reading dyno? Or do you want a TRUE 400whpthat will make 400whpon almost any dyno out there?
In general you can hit 400whpon pump gas with something like (this is speaking of a 2.5L motor)
FP green turbocharger(this is larger than a 20G, its a 20G with a 49lb wheel)
Intake (GOOD intake, there are a few)
Front mount intercooler
Injectors
Pump
turboback exhaust. Catless prefered for this turbo and power goal. 3" would definately be recommended but 2.5 wouldnt hold it back much if at all.
Headers or P&P manifold and better crossover pipe.
Larger/better up pipe Definately recommended.
Custom tune obviously, and to hit 400whpyou will likely need 24+PSI.
If you run alcohol injection you will get there easier and safer at a little lower boost. This setup will not reach 400whpon all dynos, but it will get you there on most.
Or, and this would MUCH more easily hit 400whp, and on many more dynos. I consider this a "true" 400whpsetup.
GT30R rotated mount turbo kit
Header to go with whatever up pipe that setup uses, even better if they make a header specifically for their rotated kit.
Injectors
fuel pump
Intake (this will be part of the rotated kit most likely)
Custom tune obviously.
Alcohol injection, again would allow lower boost/safer tune to hit 400whp, but this setup shouldnt have any problems hitting 400whpon pump gas by itself. Well over 400whpon race gas, I have seen 500whp on this setup with race gas on a semi high reading dyno.
So great, now you have 400whp.
Lets look at what the hidden costs are.
Clutch- Stock wont last long for 95% of people with this much power.
Flywheel- most do a light flywheelwhen they do a clutch. You may or may not.
Motor mountsare HIGHLY recommended at this point. Thats a lot of TQing around that the motor will be doing. The stock mounts were designed to hold a 300chp/300ctq motor still and keep noise at a reasonable level. If you are putting 400 to the WHEELS you are easily at 475 crank hp. Over 50% past what the stock mounts were made to handle.
Then lets look at the reliability limit of the stock motor.
400whphas been, since 2004 when the 2.5 came out shown itself to be the reliability limit of the stock pistons/rings. The rule of thumb is, upgrade the turbo, plan on a new shortblock. On something like a 20G or larger, at 20+PSI boost, its no longer a matter of IF, but when. There are of course some rare cases where someone makes 400whpfor 50k+ miles, but believe me when I say this, that is RARE. Many with a good tune blow up well below400whp. Best case scenario, pull the motor out and do pistons before you even install your 400whpsetup. The crank/rods should be fine at this powerlevel. Even so, doing a set of pistons can be a close to or just over $2000 investment, depending on what pistons and installer you use. Plan on at least $1500 to get some good forged pistons into your motor. Remember you will be paying for a full gasket kit, and with the motor apart a new timing beltandwater pumpis never a bad idea. Figure in oil and a filter as well. Small cost parts, but it adds up very quickly.
Then lets look at the safety aspect. 400whpis a LOT of power. In the hands of an unexperienced driver, it is quite litterally a deadly amount of power, especially so in an AWD carthat can put the power down. 400whpin a RWD car is one thing, stomp on the gas at 40mph and you get massive wheelspin. Do it in an AWD carand you get hard acceleration. Are you experienced enough? The answer is in almost every case, no. Why? Lets use an example.
You are doing 65mph on the highway in a stock STI, or even light mods. You want to pass someone. Most will pass at roughly 85mph to get around that person. So you give it X amount of throttle, you dont look at the speedo because you have done it a million times, and you accelerate to 85mph.
Now lets swap that out for a 400whpcar.
You are doing 65mph, you apply the same amount of throttle to do it, you are VERY quickly doing 90mph, you feel how hard it pulls so you back off a bit, but its all relative and even though it doesnt feel like its pulling as hard, its still pulling harder than it was when stock/lightly modded. You are doing well over 100mph by the time you get around that car.
Now someone comes over into your lane forcing you to turn and go around them while braking HARD. This is a delicate move.
Or, you decide you want to do a hard long pull. The kind that we all love, that puts a big dumb grin on our faces from feeling the seat pushing into our backs. You would have previously made it up to maybe 100-110mph.
So you are in the same place, same stretch of road. You do it again. Now you are doing 140 where you would have been doing 100. Go ahead, hit a bump at 140mph, and see how it feels. What was a "whump" at 100mph can quite litterally throw a 140mph vehicle into the air.
Your STI is a high performance vehicle that can handle high speeds and save your butt from a lot of dumb moves, but its not magic. AWD and the yaw sensors and such can only do so much, they arent miracle workers.
And if not for your own safety, think about what happens if you are doing the kinds of speeds you will EASILY hit with this kind of power and you hit another vehicle.
You may say "yeah but I wont do that kind of thing" That is all well and good, but the reality is that the more power you have, the more often you will drive at higher speeds than you did at the lower power level. I dont care who you are, its an almost 100% chance.
So lets review.
Do you REALLY know what this power goalwill end up costing you?
Are you prepared to spend that kind of money?
Are you a good enough driver to handle that kind of power?
Have you even driven a 350whp STI?
My advice to those with a stock/lightly modded (like AP stage 2) STI/WRX, would be to take it in smaller steps. Most of the people I have met that wanted400whp, were scared out of their mind when I took them out in a 330whp subby. Heck my 309whp 2.0Lwrx scared a lot of them.
Do this if you have a "stage 2" car(make sure you have these parts)
Custom tune. A GOOD custom tune. Do research before you pick a tuner. just because they own a shop doesnt make them good.
Full exh.
FMIC
20G@20PSI
injectors and pump.
Because that will be as much or more than 90% of people here will ever want or need. If you want more, drive that around for 6 months to get a handle on what the power is like.
if you are bone stock,
Do this.
Full exh
GOOD custom tune
Of course much of this is opinion, however this is opinion coming from 18+ years of driving, 15+ of those in high powered cars, 10 years of import scene and tuning experience and 5 years of Subaru specific tuning/driving and really importantly in this case, Meeting and speaking to people on Nasioc. So I like to think that it holds SOME truth to it at least
Opinion or not, I assure you the message behind it holds true and you should really take it all to heart if 400whpis your true goal.
Source -
http://forums.nasioc.com/forums/showthread.php?t=1393580
This is very nice to read, and so much true in it... took me 3 months to get used to 160hp(coming from 50hp corsa), and after 18 months of daily driving 160hp, I do not dare call myself neither good driver, nor driver able to use all of its potential...
yet again, I went ahead and upgraded to 220hp, and honestly? After a month of daily driving, I am not getting blown away(the feel that we all love) any more, but I am still far far far away from knowing how to handle that car properly...
Sure, hitting 250hp with that would be nice, but not just yet(brain says)... but I will feel again for a week that thingie that I love(says heart/or d*ck? I am not sure)...
I've had more fun is less powerful cars than powerful ones
there's more to making a great car than just power
Brakes and suspension are a far more important role In Having the perfectly setup car for whatever driving style you have in my Un educated opinion :thumb:
Cant answer that bit.
Even on dyno dynamics sent there. Are calibrated differently from source.
As you can see in article above on FP green 400whp. Suggesting 20g be what 380whp.
Now all dyno calculate differently. From Maha, DD, dastek etc.
So a 380bhp whp on one might be 480bhp flywheel.
Another be 450bhp flywheel
Another be 475 bhp flywheel
Now any of the above not realistic on a 20g this side of pond. Can take about 25-30% of american figures to ours.
