Page 95 of 96 FirstFirst ... 4585888990919293949596 LastLast
Results 1,881 to 1,900 of 1904
Thread: Track day car
  1. #1881
    Full ISDC Club Member MARTINGTI's Avatar
    Jan 2013
    1,382
    313
    1
    11
    Your dead right. That barrier time I just don't like. That car deserves. To be running flat out and your well capable of having it near the front. I'll be watching closely! 👍
    Point it and shoe it!
  2. The Following User Says Thank You to MARTINGTI For This Useful Post:
    Adrian Dunne (20-09-2018)
  3. #1882
    Aug 2013
    Tyrrellspass
    2,187
    556
    15
    Cheers Martin.
    Some mods planned for the winter which will help her along hopefully
  4. #1883
    Aug 2013
    Tyrrellspass
    2,187
    556
    15
    https://motorsport.ie/2018/09/21/ins...-adrian-dunne/
  5. The Following User Says Thank You to Adrian Dunne For This Useful Post:
    Gary sti (21-09-2018)
  6. #1884
    Aug 2013
    Tyrrellspass
    2,187
    556
    15
    The next little stage of development has started today. In the pursuit to get even lighter I have removed original fuel tank. I will fit a new 12 ltr fuel cell in its place. Iím looking to locate this more on the passenger side. The plan is to have a built in swirl pot at the bottom which will mean I wonít need a lift pump in the tank. An in-line pump under the bonnet should work fine.
    I also plan to re direct the the exhaust under the car to make more room for some aero. Iíll try flat bottom the car as well as possible and make a small rear diffuser.
  7. The Following 2 Users Say Thank You to Adrian Dunne For This Useful Post:
    Gary sti (23-09-2018), scooby ed (30-09-2018)
  8. #1885
    Commitee Member / ISDC Event Organizer GORDON GT SERIES II's Avatar
    Mar 2008
    offaly
    7,246
    1,703
    1
    34
    Class job as always Adrian this car gets better and better and that will help with searching for quicker times no end
  9. The Following User Says Thank You to GORDON GT SERIES II For This Useful Post:
    Adrian Dunne (23-09-2018)
  10. #1886
    Aug 2013
    Tyrrellspass
    2,187
    556
    15
    Quote Originally Posted by GORDON GT SERIES II View Post
    Cheers Gordon
    Looking forward to this little job.
  11. #1887
    Aug 2013
    Tyrrellspass
    2,187
    556
    15
    In further efforts to clean up under the car for flat flooring, we have decided to run a side exit exhaust. By removing the existing back box and mid section I was able to cut back the front pipe and fit a nice new 24Ē Profusion centre pipe. After this pipe the tail pipe will exit at 110 degrees just in front of the rear driver side wheel. Pipefab in Tullamore will make the rear section for me and Iíll fit it myself. Hopefully it wonít be too loud or cause any power issues. I was very happy with the Supersprint and Kam Racing setup, but needs must for space.
    The new centre box is 24Ē long and 3Ē diameter so fits perfectly inside the tunnel.
    Very rough draft of what it will look like. The plan is to increase the end pipe and have it flattened for a more flush side exit.
    First little mock up of the location to make sure it fits ok.
    Hopefully my fuel tank will be ready and land next week so I can get that fitted. Very early days yet but Iíll get small bits done as I can afford to do them.
    Looking at adding 1.5 rear negative camber and also adding 12mm track to either side.
  12. The Following 2 Users Say Thank You to Adrian Dunne For This Useful Post:
    dontommy (29-09-2018), Gary sti (28-09-2018)
  13. #1888
    Aug 2013
    Tyrrellspass
    2,187
    556
    15
    Seen this just went up on YouTube today. Itís the coverage from our races in Kirkistown last June. Great coverage and a great weekend
  14. #1889
    Aug 2013
    Tyrrellspass
    2,187
    556
    15
    My latest bit of work was to start fitting the 20ltr fuel cell. Very impressed how light this actually is. It has a built in swirl pot and foam filled which will stop any surge.
    There was s few reasons for going with the fuel cell, but the main reason is always to save weight. As I want to do a full flat floor, ďas much as possibleĒ removing the oem tank letís me run a tidy side exit exhaust which will move up nicely under the flat floor. Side exit is something I always wanted to do but I knew the fuel tank needed to go first.
    This is the location Iíll be fitting the tank. Iím keeping it on the passenger side and as far forward as possible for better weight distribution.
    Location marked out so time to start cutting..
    Hello floor:)
    Final cutting done and profile all edges. You can see the extra cuts for the swirl pot and line connectors.
    Very happy with the fitment now. Before I fix this in place Iíll be getting under the car to give it some TLC.
    I have been building and racing this car for near 4 years now so itís well due. This car has very little rust but done areas have surface rust. Iíll clean everything very well and coat all areas with a suitable gunk!
    Of course Iíll eventually have to build a fire wall around all this when finished.
  15. The Following User Says Thank You to Adrian Dunne For This Useful Post:
    dontommy (06-10-2018)
  16. #1890
    Committe Members Ciaran WRX's Avatar
    Jan 2013
    Ireland
    12,155
    4,819
    1
    61
    Real impressive work as uasual Adrian
    Some man
  17. The Following User Says Thank You to Ciaran WRX For This Useful Post:
    Adrian Dunne (06-10-2018)
  18. #1891
    Aug 2013
    Tyrrellspass
    2,187
    556
    15
    Track day car
    Thanks Ciaran
    Loads more interesting bits to do so could be a busy winter
  19. #1892
    Aug 2013
    Tyrrellspass
    2,187
    556
    15
    Over the past few days I have started making the back section for me side exit exhaust. Original I gad tasked someone else with this job as my welding skills wouldnít be the best, but unfortunately I was let down on this. So I decided to just give it a lash, as learning is what this car is all about after all.
    My main section was always 50mm so no need to go any bigger really. I picked up a 2M Bosal 50mm pipe and a solid 90 degree bend which was perfect for the job. Iím lucky to have a handy band saw so straight cuts wasnít a problem while making this.
    Tonight I got the main brackets finished and have it hanging nicely under the car. This should now be up far enough to allow me better clearance for the flat floor. Everything got a lick of silver VHT paint. I will need to remove this again so I can tidy and paint under the car. I also need to make an aluminium plate for the skirt where the exhaust exits.
    I also have the fuel tank in its final resting place. Again Iíll need to remove this for painting, but once thatís done I can start working on the firewall and pipe work.
    Long winter ahead and still plenty to do. Wonít see huge gains with these bits, but all bits I wanted to get done to help make it a better race car overall.
  20. The Following 2 Users Say Thank You to Adrian Dunne For This Useful Post:
    dontommy (17-10-2018), Pedro555 (17-10-2018)
  21. #1893
    Aug 2013
    Tyrrellspass
    2,187
    556
    15
    Got a spare few hours tonight and just finished off the exhaust. Happy with how itís all fitting just hope it sounds ok!
  22. #1894
    Aug 2013
    Tyrrellspass
    2,187
    556
    15
    Sorry looking sight tonight..
    While cleaning all under the car and painting, I have decided to clean and paint the inside. Not a job Iím enjoying as I should have done it the last time I stripped the car. That said the results should be worth it. Iíll paint it all white inside and possibly even give the cage a fresh paint job.
  23. #1895
    Aug 2013
    Tyrrellspass
    2,187
    556
    15
    New rear axel kit!
    Adds 1.5 degree negative and extra 12mm wider on each side. This should add some rear end stability:)
  24. The Following 2 Users Say Thank You to Adrian Dunne For This Useful Post:
    Ciaran WRX (01-11-2018), Gary sti (01-11-2018)
  25. #1896
    Member Number 2766
    ISDC Club Treasurer
    scoobysub's Avatar
    Nov 2008
    kilkenny
    12,010
    2,755
    1
    10
    This is getting serious now . Great work Adrian
  26. The Following User Says Thank You to scoobysub For This Useful Post:
    Adrian Dunne (01-11-2018)
  27. #1897
    Aug 2013
    Tyrrellspass
    2,187
    556
    15
    Cheers Joe! Iím hoping little changes will make a big difference
  28. #1898
    Jan 2013
    Ireland
    12,155
    4,819
    1
    61
    Savage
  29. The Following User Says Thank You to Ciaran WRX For This Useful Post:
  30. #1899
    Aug 2013
    Tyrrellspass
    2,187
    556
    15
    Just need to find time to get some work done
  31. #1900
    Aug 2013
    Tyrrellspass
    2,187
    556
    15
    Itís been 4 years since I started this thread guys.. Thanks for all the support advice and comments. Still a long way from finished but certainly has come a long way.
    Needless to say this snowballed a little but itís been fun:)
  32. The Following 3 Users Say Thank You to Adrian Dunne For This Useful Post:
    dontommy (03-11-2018), Gary sti (03-11-2018), Markokavo (03-11-2018)
Similar Threads
  1. Non wide track blob and wide track...
    By Ciaran WRX in forum How to...
    Last Post: 29-10-2014, 01:50
  2. Replies: 8
    Last Post: 21-12-2009, 10:02
