Track day car
[emoji23][emoji23] that's your new name ya would an iron bar in a bog hole [emoji849]
Sent from my F8331 using Tapatalk
Cheers man!
Yes I need to learn the cars limits. But the plan is to get someone to bridge the three bolt holes not with some tig welding. Make it stronger [emoji106]
Get Dec to chat Anthony Culleton be handy ????
Sent from my SM-G930F using Tapatalk
Just seems to be a weak spot on the top of the box. Better to address it now before re fitting it[emoji106]
Time has not been on my side but I finally got my gearbox repaired and back together. I got Gorry stainless steel in Tullamore to weld a gusset onto the casing mount points to help strengthen the part that broke on my last casing. I made sure to strip down the box and inspect everything and make sure no metal got in, and all is good. As far as bearing and gears go all looks fine and should be good for next season. It would be rude not to get a bit of paint on while I’m at it:)
Gearbox going back in last night!
No engine crane to lift up the gearbox so had to use my shovel and some wire and clamp into place with vice grips.. not very safe but needs must[emoji16]
More than one way to skin a cat lads[emoji23]
All back together now and done a little winter testing [emoji38]
Some alignment issues to be sorted and a fukd alternator, but other that it’s good to go..
