Own leggy head unit
dave b
As above have a 99b4 it still has crap hap radio I'm lookin to change it to single din anyone know where to get the part to fit single din? Also I noticed car has no aerial
Cheers
You just need a pocket from Subaru single din will screw in to the factory cage.
Only issue is if yours is the amped macintosh version you may need a professional to look at that.
The aerial is built into with the front or rear windscreens
Thanks baz is this the dreaded macintosh
I've had experience with this in my old legged and if it's amped you don't need a specialist you just need some cop on. And a decent multi meter. When you get your single din you will have to splice the wires on the current set up to the iso that will come with your new head unit. You just need to figure out what wire is for what speaker and which is power and earth and so on.
