Re: Re: Looking someone who knows twin turbo legacys well
[quote author=william davidson link=topic=41984.msg1#msg1 date=1402947581]
Cel coming on from 3500 to 4300 ish code 65 differential pressure sensor
Low boost on secondary and intermittent code 66 twice if that makes. Changed dps and no difference. Did have code 45 but cleaned out vacuum lines, intercooler and all the solenoids and got rid of that
need take live voltage readings from dps. doubt was/is that.
basically need to go through the whole system.
prob i find is that when someone has a problem with one they are unable to leave it with you and dont realise that you could be 2 hrs at it or 10 hrs.
