2.33 Stroker Short engine.
davelegacy
Member Number 16
[size=12pt]
- EJ22 Pinned Block. Vapour Blasted So as new. (pic before and after as example)
- Block head surface Decked and 0.5mm overbore . Clearence will be decided for customers intended usage.
- EJ257 2.5 Crankshaft checked and polished.
- ACL Race big and Main Bearings
- New K1 Forged Conrods with ARP2000 bolts
- New Wiseco .5mm oversize pistons and rings.
- Brand New Subaru Oil Sump
-Brand New Subaru 10 or 11mm oil pump. again depending usage and heads being used etc.
[/size]
assembled short engine e2995.00
14mm head stud machine work option + e295.00
Re: Re: 2.33 Stroker Short engine.
[quote author=Altezza-Dan link=topic=41577.msg1#msg1 date=1398625124]
Do you have the vapour blasting gear there Dave?
not yet. hopefully within next 6 months. not cheap set up
