[quote author=Altezza-Dan link=topic=41524.msg475376#msg475376 date=1398170321]
He couldn't remap it that's the main problem I guess. 190 at the fly is terrible!
is it accurate,[quote author=Adrian Dunne link=topic=41524.msg475378#msg475378 date=1398170862]
[quote author=Dagnut link=topic=41524.msg1#msg1 date=1398170071]
[quote author=Adrian Dunne link=topic=41524.msg475371#msg475371 date=1398167183]
[quote author=Altezza-Dan link=topic=41524.msg1#msg1 date=1398165445]
[quote author=Dagnut link=topic=41524.msg475354#msg475354 date=1398121710]
[quote author=KENC link=topic=41524.msg475335#msg475335 date=1398113454]
Is the white one used to code remote key or something like that.
Afaik, being able to reset the ecu ended with the classic impreza, all new ones need a computer to reset them.. Presume legacy is the same
Strictly speaking you aren't resetting it, but if disconnected the current setting will be wiped , worked on previous model legacy
If you pull the battery for a while it wipes the learned knock values and AFR stuff and also resets the IAM back to 1 so it would erase any previous retardation the ecu detected because of a knock event or similar, at least it does on mine.
I was chatting Aunghus this morning he is going to have another look at mine now that we know where the connectors are!
When he ran mine on the dyno he said it was knocking like crazy so didn't like the sh*t fuel I guess,hard to believe it would cause such a power loss!
Have you tried a decent booster or some toluene or something just to see? if you were getting poor quality fuel it could easily account for the retardation in timing(if it is that)
Did he give you an at the wheel figure, just out of interest? I don't think 210hp would be unreasonable for an auto JDM legacy running shite 95...a couple of % wrong in transmission loss calculation would screw up your flywheel figure...you see all types of % transmission losses used by dyno operators, especially as it is an Auto, the auto runs 40/60 torque split doesn't it? It may lose less power through the transmission? just a guess work btw I'm not suggesting this is the case but We've seen at dyno days before they will just use a standard calculation for all Subarus....different diffs , different gearing etc will all make the difference, ....does the car fell really sluggish or is it just the low read out that is troubling you?
Funny enough the car feels a bit better than 190bhp it seems to lack power at top end more so,
I put some booster in it Friday night I got it of Aunghus but I wouldn't like to be buying it for every fill"didn't make a big difference anyway.
I'd hope he can sort something if he gets to read the Ecu next time.
I think your wright with the split I'm pretty sure the auto is around 40/60 to the rear.
I wouldn't take that 190bhp as gospel if I were you, get the wheel reading.
