RSR Automotive Uprated Fast Road Brake Disc options
davelegacy
Member Number 16
Available in a groove pattern or dimple groove pattern.
Available for all makes and models. Not just Subaru.
Pads also available.
Some of more popular Subaru range pricing:
#Prices Subject to Change. Correct as May 2015#
Front 2pot 277mm disc pair £109.50/€154.50
Front 4pot 294mm disc pair £114.50/€159.50
Front Brembo 326mm disc pair £139.50/€189.50
Rear 1pot 266mm disc pair £109.50/€154.50
Rear 2pot 290mm disc pair £109.50/€154.50
Rear 2pot 290mm STi Type R disc pair £184.50/€264.50 (excluded from 10% member discount)
Rear brembo 316mm disc pair £134.50/184.50
Fitted to rear Legacy B4 Twin Turbo 2001
Re: Re: RSR Automotive Uprated Fast Road Brake Disc options
[quote author=daveR link=topic=40923.msg1#msg1 date=1393237966]
Fitted to my b4 aswell :icon_grin:
How are you finding them?
Can hasnt moved an inch since they were fitted dave. Still more work to do before i start driving it but ill let you know how things go.
They look sweet though :afro:
looking for the folowing Dave , in 114.3 for widetrack car
plus pads ,
fire us back a price there and will probably order come payday ,
cheers
[quote author=Tommy 555 link=topic=40923.msg1#msg1 date=1403211735]
plus pads ,
cheers
Hi
What pads had you in mind
[quote author=Tommy 555 link=topic=40923.msg1#msg1 date=1403254069]
what you recommend dave . dont need full on track day pads just something with a decent bit of bite
3options
I like CL RC6 from brake feel. But squeel may annoy you.
EBC Yellowstuff is second option.
Or more budget Pagid oem.
If were moving up the scale further in the pad market then you would also move up to next level of disc etc.
remember nick spec c had the cl on his . the squeal when cold would wreck my head so id say the ebc might be best .was considering 2 piece disks like the ones baz got on his but have decided to leave the car alone performance wise so standard type disks will do fine I think . think the fronts have warped on mine and rears are due a change anyway so may as well go do the lot together
Dave
What's the difference between the rear 2 pots 290mm and the rear 2pots off a type r 290mm??
[quote author=DUFFMAN™ link=topic=40923.msg1#msg1 date=1403266054]
Dave
Discs?
Handbrake shoe 170mm and 190mm
Also ones above are genuine subaru. Not made aftermarket.
Looking to get Subaru 4 pot callipers for front and 2 pot for rear and upgraded discs and pads all round for a 02 B4 Leggy, suggestions and price Dave??
I suggest 4 pots on front with dimple grooved discs and pads.
And then on rear leave calipers and do dimple grooved discs and pads. And add goodridge braided brake lines for money saved on rear calipers
And flush and bleed with Motul RBF600.
