April 2013 mapping
Standard car can be but power gains will be less than if the car is modified.
Can be redone to less decent fuel if you cant get good stuff.
Perhaps a health check with detcans and ecu plugged into the laptop and see how it is would be best first move.
What year is the car and sti/wrx import etc?
Thanks
Simon
its a 2001 bug eye wrx car is standard bar a air filter dump valve and by looks of it non standard back box no name on box she done 68,000 miles hope this helps luke
[quote author=lukeewrx link=topic=37114.msg426234#msg426234 date=1362310539]
Air filter an induction kit?
[quote author=Sti TypeR link=topic=37114.msg426286#msg426286 date=1362337045]
Hello Simon,
Where do you do the mapping?
Regards
Mike
Based at One Performance but travel to North Also so might be able to meet if dublin no good
[quote author=lukeewrx link=topic=37114.msg426323#msg426323 date=1362348069]
induction si
Worth checking then as it can effect maf voltage
Hi Simon.
I've an ecutek map on my 04 spec-c, standard ecu.
Done a few years ago.
Could you do a tweak/check map on it?
would love anti-lag also if it were at all possible?
Any idea on cost please.
Thanks. (Based in Dublin)
Grahamo.
I can only tweak the map if I did it. You can read the current map off with ecutek.
No issue to check it and remap if required.
Not possible to do antilag but can add some noise on the overrun.
Thanks
Simon
Hey Simon,
I'm new to the Subaru scene. I'm just wondering if it's possible to map an automatic Forester STI ?
It's a 2000 SF5 (Jap import) and if so, can you map in an over run with an auto box ?
Thanks for getting back to me.
Hopefully I'll make the April mapping session, all going well.
well simon have 03 blob wrx import! with full exhaust, dump valve, no other mods, can standard ecu be mapped for irish fuel and a little more power? and also if its mapped without cat will it pass emmisions tests, or will putting cat in for car tests drive ecu mad? also when are ya back in ireland? thanks
