Well a day off work full tank and back roads around Meath then Dublin mountains she loves wet slippy roads great crack puts a big smile on my face......
Replaced steering rack (feeder lines were awkward but not too bad otherwise) fitted whiteline bushes and bump steer kit - big difference and no more knocking !!!!
Failed nct on Reg plates ????
Nearly sure I got plates that would pass test ????
Other than that he said car was mint and as they should be kept !
I always carry my legal plates with me in the boot. I was also fitting and refitting them in front of the tester in the nct - talking about arrogance :facepalm:
I had problems with those same plates, they have to have bigger text, spacing and the hyphen in between.
May find old plates I took off so..
Is that not false advertisement saying they are legal ?
Yes on 2 counts. 1. Not fit for purpose and 2. not as described. You're entitled to a repair, refund or replacement under the sale of goods and supply of services act.
If they dig their heels in, make a complaint to the NSAI and CCPC. Both very helpful.
Signed off the road for few months.
Removed the Tein suspension and EDFC controller from the spec c and fitted a set of spec c Ra-r 4 way adjustable struts .
There the same as the S204 suspension struts but with 4 adjustments on the bottom nut from hard to soft . Very happy with the handling and the way it sits now .
The tein’s were new and only covered 10k from New and the EDFC controller meant you could change from soft to hard or anywhere in between at the touch of a button Which is very handy . But the pink Sti suspension is a nicer feel on the road not cheap but worth it :thumbsup:.
